Gst-nvdsdynamicsrcbin (developer preview)#
The Gst-nvdsdynamicsrcbin plugin is a custom GStreamer element designed for high decoder throughput scenarios. It creates a single pipeline that keeps the decoder active at all times, eliminating decoder initialization overhead when switching between multiple video streams.
The plugin accepts video files as input sources and dynamically manages them through signals. The Gst-nvdsdynamicsrcbin plugin performs dynamic source management, enabling seamless switching between multiple video streams without pipeline reconstruction.
Key Features:
Single active decoder instance for multiple sources
Dynamic source addition and removal via signals
Custom events for source change tracking
Thread-safe source queue management
Hardware decoding with nvv4l2decoder
The plugin maintains internal queues and maps to track active sources and their corresponding file paths, enabling seamless switching between multiple video streams.
Inputs and Outputs#
This section summarizes the inputs, outputs, and communication facilities of the Gst-nvdsdynamicsrcbin plugin.
Inputs
Video files (any format supported by GStreamer parsebin)
Dynamic source addition signals (add-source)
Source removal signals (remove-source)
Termination signals (terminate)
Control parameters
Gst-nvdsdynamicsrcbin gets control parameters from signals and GObject properties. The following control parameters can be set through GObject properties:
GPU ID for hardware decoding
Current file being processed (read-only)
Current source ID being processed (read-only)
Outputs
Gst Buffer with decoded video frames
Custom metadata containing source identification
Application messages for dynamic source changes
Features#
Gst-nvdsdynamicsrcbin plugin features# Feature
Description
Benefit
Single Active Decoder
Maintains one decoder instance for multiple sources
Eliminates decoder initialization overhead
Dynamic Source Management
Add/remove video sources via signals without pipeline reconstruction
Enables real-time source switching
Hardware Decoding
Uses nvv4l2decoder for GPU-accelerated video decoding
Improved performance and throughput
Thread-safe Operations
Protected source operations with mutexes
Concurrent signal handling support
Custom Metadata
Attaches source ID and frame ID to each buffer
Enables source tracking and identification
Custom Events
Stream start and EOS events with source identification
Provides source change notifications
Internal Queue Management
Maintains queues for active and pending sources
Seamless source switching
Application Messages
Posts messages for source change notifications
Enables application-level monitoring
Format Detection
Automatic media format detection via parsebin
Supports various video formats
Performance Optimization
Keeps decoder warm and ready for rapid switching
Reduced latency between streams
Element Architecture#
The nvdsdynamicsrcbin element contains the following internal elements:
filesrc: Source element for reading video files
queue_filesrc: Buffering queue for source data
parsebin: Media format detection and parsing
queue_parsebin: Buffering queue for parsed data
nvv4l2decoder: Hardware decoder (kept active throughout)
The element maintains internal queues and maps to track active sources and their corresponding file paths, enabling seamless switching between multiple video streams.
Supported Signals#
The nvdsdynamicsrcbin element supports three key signals for dynamic source management:
add-source Signal: Purpose: Adds a new video source to the dynamic source bin Parameters: file_path (string), source_id (integer) Usage: g_signal_emit_by_name(dynamicsrcbin, “add-source”, “/path/to/video.mp4”, source_id); Behavior: Validates file path, prevents duplicate source IDs, stores mapping, adds to internal queues, links elements for first source
remove-source Signal: Purpose: Removes a video source from the dynamic source bin Parameters: source_id (integer) Usage: g_signal_emit_by_name(dynamicsrcbin, “remove-source”, source_id); Behavior: Sends EOS for active sources, removes from tracking for queued sources, cleans up data structures, posts file change message
terminate Signal: Purpose: Terminates the entire pipeline gracefully Parameters: None Usage: g_signal_emit_by_name(dynamicsrcbin, “terminate”); Behavior: Sends EOS event from decoder, posts termination message, cleans up resources
Custom Events and Metadata#
Custom Stream Start Event: Event Name: “custom-stream-start-event” Contains: source-id parameter Purpose: Notifies downstream elements when a new source begins processing
Custom EOS Event: Event Name: “custom-eos-event” Contains: source-id parameter Purpose: Notifies when a source completes processing
Source Metadata: The element attaches custom metadata to each buffer containing: * chunk_id: The source ID that generated the buffer * frame_id: Sequential frame counter for the current source
Gst Properties#
The following table describes the Gst-nvdsdynamicsrcbin plugin’s Gst properties.
Property Name |
Type |
Access |
Description |
Default Value |
async-handling |
Boolean |
readable/writable |
The bin will handle Asynchronous state changes |
false |
current-file |
String |
readable |
Current file being processed |
null |
current-id |
Integer |
readable |
Current id of the chunk being processed |
-1 |
gpu-id |
Unsigned Integer |
readable/writable |
GPU Device ID to use for decoding |
0 |
message-forward |
Boolean |
readable/writable |
Forwards all children messages |
false |
name |
String |
readable/writable |
The name of the object |
dynamicsrcbin0 |
parent |
GstObject |
readable/writable |
The parent of the object |
null |
Performance Benefits#
Eliminates Decoder Initialization Overhead: When you add N streams to a traditional pipeline, each stream typically requires its own decoder instance with initialization time. The nvdsdynamicsrcbin element maintains a single active decoder, significantly reducing latency when switching between streams.
Improved Throughput: By keeping the decoder warm and ready, the element can handle rapid stream switching without the performance penalty of repeated decoder initialization.
Dynamic Source Management: The element supports real-time addition and removal of video sources without pipeline reconstruction.
Reduced Latency: Maintains single active decoder instance for improved performance in multi-stream scenarios.
Rapid Source Switching: Enables switching between streams without performance penalty.
Usage Examples#
The following example demonstrates how to use the nvdsdynamicsrcbin element in a GStreamer pipeline:
Basic Pipeline Setup:
// Create pipeline elements
GstElement *pipeline = gst_pipeline_new("dynamicsrcbin-test");
GstElement *src = gst_element_factory_make("nvdsdynamicsrcbin", "src");
GstElement *sink = gst_element_factory_make("fakesink", "sink");
// Add elements to pipeline and link them
gst_bin_add_many(GST_BIN(pipeline), src, sink, NULL);
gst_element_link_many(src, sink, NULL);
// Set pipeline to PLAYING state
gst_element_set_state(pipeline, GST_STATE_PLAYING);
// Add sources dynamically
g_signal_emit_by_name(src, "add-source", "/path/to/video1.mp4", 0);
g_signal_emit_by_name(src, "add-source", "/path/to/video2.mp4", 1);
// Remove sources
g_signal_emit_by_name(src, "remove-source", 0);
// Terminate pipeline
g_signal_emit_by_name(src, "terminate");
Monitoring Source Changes:
// Add probe to monitor frame processing and source changes
GstPad *sink_pad = gst_element_get_static_pad(sink, "sink");
gst_pad_add_probe(sink_pad,
GST_PAD_PROBE_TYPE_BUFFER | GST_PAD_PROBE_TYPE_EVENT_DOWNSTREAM,
sink_input_buffer_callback,
NULL,
NULL);
Sink Input Buffer Callback:
static GstPadProbeReturn sink_input_buffer_callback(GstPad *pad, GstPadProbeInfo *info, gpointer user_data) {
if (GST_PAD_PROBE_INFO_TYPE(info) & GST_PAD_PROBE_TYPE_BUFFER) {
frame_count++;
g_print("Frame Number: %d, Current Source ID: %d\n", frame_count, current_source_id);
} else if (GST_PAD_PROBE_INFO_TYPE(info) & GST_PAD_PROBE_TYPE_EVENT_DOWNSTREAM) {
GstEvent *event = GST_PAD_PROBE_INFO_EVENT(info);
/* Check for custom stream start event from nvdsdynamicsrcbin */
if (GST_EVENT_TYPE(event) == GST_EVENT_CUSTOM_DOWNSTREAM) {
const GstStructure *structure = gst_event_get_structure(event);
if (structure && gst_structure_has_name(structure, "custom-stream-start-event")) {
gint source_id;
if (gst_structure_get_int(structure, "source-id", &source_id)) {
g_print("Source change event received for source ID: %d\n", source_id);
current_source_id = source_id;
/* Reset frame count for new source */
frame_count = 0;
return GST_PAD_PROBE_OK;
Dynamic Source Message Handler:
static gboolean handle_dynamic_source_message(GstElement *dynamicsrcbin) {
int current_id = -1;
gchar *current_file = NULL;
GstElement *filesrc = get_element_by_factory_name(GST_BIN(dynamicsrcbin), "filesrc");
GstElement *queue = get_element_by_factory_name(GST_BIN(dynamicsrcbin), "queue");
GstElement *parsebin = get_element_by_factory_name(GST_BIN(dynamicsrcbin), "parsebin");
if (!filesrc || !queue || !parsebin) {
g_print("One of the elements not found\n");
} else {
/* Stop and remove old elements */
gst_element_set_state(parsebin, GST_STATE_NULL);
gst_element_set_state(queue, GST_STATE_NULL);
gst_element_set_state(filesrc, GST_STATE_NULL);
gst_bin_remove(GST_BIN(dynamicsrcbin), filesrc);
gst_bin_remove(GST_BIN(dynamicsrcbin), queue);
gst_bin_remove(GST_BIN(dynamicsrcbin), parsebin);
/* Get current file and ID from nvdsdynamicsrcbin */
g_object_get(G_OBJECT(dynamicsrcbin), "current-id", ¤t_id, NULL);
g_object_get(G_OBJECT(dynamicsrcbin), "current-file", ¤t_file, NULL);
g_print("Current ID: %d, Current File: %s\n", current_id, current_file);
if (current_file && current_id) {
gboolean ret = load_file(dynamicsrcbin, current_file);
g_free(current_file);
return ret;
/* Schedule retry if file not ready */
g_timeout_add(1000, try_load_file, dynamicsrcbin);
return TRUE;
Note
Important: The handle_dynamic_source_message function is required for the nvdsdynamicsrcbin element to work properly. This function handles the cleanup of old elements and loading of new sources when dynamic source changes occur. Without proper implementation of this handler, the element will not function correctly and may cause pipeline failures.
Bus Message Handling:
// Handle dynamic source change messages
static gboolean bus_call(GstBus *bus, GstMessage *msg, gpointer data) {
switch (GST_MESSAGE_TYPE(msg)) {
case GST_MESSAGE_APPLICATION: {
const GstStructure *str = gst_message_get_structure(msg);
if (gst_structure_has_name(str, "dynamic-src-bin-file-change")) {
// Handle source change
handle_dynamic_source_message(dynamicsrcbin);
break;
// ... other message types
return TRUE;
Technical Notes#
The element uses GStreamer’s parsebin for automatic format detection
Hardware decoding is performed using nvv4l2decoder
Custom metadata is attached to buffers for source tracking
Thread-safe operations ensure concurrent signal handling
The element posts application messages for source change notifications
Internal queues and maps track active sources and file paths
Mutex protection ensures thread-safe source operations
Compilation and Installation#
To compile and install the plugin:
Export or set in Makefile the appropriate CUDA version using CUDA_VER * For x86: CUDA_VER=12.8 * For Jetson: CUDA_VER=13.0
Run make and sudo make install:
`bash $ sudo make $ sudo make install `
Note: To compile the sources, run make with “sudo” or root permission.
Testing#
Test with Sample Application:
$ cd /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/
$ git clone https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps
$ cd deepstream_reference_apps/deepstream-dynamicsrcbin-test
$ sudo make
$ ./deepstream-dynamicsrcbin-test
The sample application demonstrates:
Pipeline setup with nvdsdynamicsrcbin and fakesink
Dynamic source addition with unique IDs
Sequential processing with active decoder
Frame processing monitoring
Source change tracking
Graceful pipeline termination
Configuration#
Modify N_CHUNKS in the source code to change the number of sources
Update VIDEO_FILE path to use different video files
Adjust timing parameters in the signal thread for different test scenarios
Configure GPU ID for hardware decoding
Set queue buffer sizes for optimal performance
The plugin is particularly useful for: * Multi-stream video processing applications * Real-time video source switching * High-throughput video decoding scenarios * Applications requiring minimal latency between stream changes * Video streaming services with dynamic content
