DeepStream Can Orientation App#
The deepstream-can-orientation-app sample application is provided at app/sample_apps/deepstream-can-orientation-app for your reference. This example demonstrates can orientation detection for industrial can position and rotation angles. There are several configurations for raw data input, JPEG input and Basler camera emulation input settings. The image below shows the architecture of this reference app.
DeepStream VPI Can Orientation Application Architecture
video template would load custom lib libnvds_vpicanmatch.so to do CV-based VPI template matching for industrial can orientation detection.
Getting Started#
Prerequisites#
  • Go to the folder sources/apps/sample_apps/deepstream-can-orientation-app
  • Prepare all test sample images and reference images. Run the following command to un-compress can test and reference images into folder data, and generate raw sample image data files. Run command
    $ ./prepare_sample_data.sh
    Note
    If there is file permission issues, try with sudo.
  • Export DISPLAY environment to correct display. e.g. export DISPLAY=:0.0.
  • For Basler camera emulation test, follow instructions in deepstream-can-orientation-app/README to install and build all dependencies. This emulation does not require a physical Basler camera.
  • Users can modify and configure their Basler cameras through Pylon Viewer to create new PFS and then use it in this app.
Run DeepStream Can Orientation Examples#
  • Run tests for JPEG files with EGL display:
    $ deepstream-can-orientation-app -c ds_can_orientation_jpg.yaml
  • Run tests for GREY raw datafile with EGL display:
    $  deepstream-can-orientation-app -c ds_can_orientation_raw.yaml -r data/test_samples_raw.grey
  • Run tests for performance tests without display. Update ds_can_orientation_raw.yaml.
    sink:
       egl_display: false
       sync: false
     debug:
       print_result: false
  • Run performance tests:
    $ deepstream-can-orientation-app -c ds_can_orientation_raw.yaml -r data/test_samples_raw.grey -l
  • Run Basler Camera Emulation tests:
    $ deepstream-can-orientation-app -c ds_can_orientation_basler_cam.yaml
DeepStream Can Orientation App Configuration Specifications#
deepstream-can-orientation-app settings#
The table below indicates the group settings for ds_can_orientation_jpg.yaml and ds_can_orientation_raw.yaml.
deepstream can orientation application settings#
Group
Property
Meaning
Type and Range
Example
source
source settings
YAML node
source
uri
decodebin uri
string
uri: multifile:///opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-can-orientation-app/data/sample1/test_sample_%2504d.jpg
source
framerate
framerate for multifile source and raw format data source
string
framerate: 10/1
source
frame_settings
Raw frame setting description
YAML node
frame_settings:
format: GREY width: 870 height: 1200
source.frame_settings
format
color format, choose from [GREY, RGBA]
String: [GREY, RGBA]
format: GREY
width
width of input raw frame
Integer: >0
width: 870
height
height of input raw frame
Integer: >0
height: 1200
source
camera
Basler camera settings
YAML node
camera:
device_serial_number: 0815-0000 pfs_path: basler_cam_emulation_0815-0000.pfs width: 870 height: 1200
source.camera
Basler camera serial number
String
source.camera
pfs_path
Basler PFS setting file path
String
source.camera
width
Basler camera capture image width
Integer: >0
width: 870
source.camera
height
Basler camera capture image height
Integer: >0
height: 1200
video_template
deepstream video template plugin settings
YAML node
video_template
customlib_name
Indicate custom-lib location for video template to load
String
customlib_name: /opt/nvidia/deepstream/deepstream/lib/libnvds_vpicanmatch.so
video_template
customlib_props
Indicate the configuration settings for the custom-lib
String
customlib_props: config-file:config_video_template_can_match.yaml
sink
sink settings
YAML node
sink:
egl_display: true
sink
egl_display
Indicate whether enable EGL display
bool
egl_display: true
sink
sync
Indicate whether do snchronization on timestamp
bool
sync: true
debug
debug settings
YAML node
debug
print_result
Indicate whether print orientation result
bool
print_result: true
Custom lib libnvds_vpicanmatch.so Settings for Can Template Matching#
The table below indicates the group settings for config_video_template_can_match.yaml.
Property
Meaning
Type and Range
Example
radius
Indicate radius of the can, unit in cm
Float
radius: 3.3
distance
Indicate distance from camera to can, unit in cm
Float
distance: 12.7
center
Indicate center of the can in input raw image normalized by width
Float
center: 0.5
can_width
Indicate width of the can in input raw image normalized by width
Float
can_width: 1.0
input_width
Indicate width of input raw image, It should be the input image width
Uint32
input_width: 870
input_height
Indicate height of input raw image, It should be the input image height
Uint32
input_height: 1200
crop_width
Indicate width of dewarped inference image to be used to match with reference image
Uint32
crop_width: 500
target_x
Indicate target center in reference image in pixels
Uint32
target_x: 250
ref_image
Specify reference image parameters
YAML node
ref_image.perimeter
Indicate can circumference in reference image in pixels
Uint32
ref_image:
perimeter: 1689
ref_image.image_path
Indicate reference image path, must be in color format GREY
ref_image:
image_path: data/reference_sample.grey
ref_image.image_format
Indicate reference image color format, only GREY supported in this version
String: fourcc
ref_image:
image_format: GREY
ref_image.image_width
Indicate reference image width
Uint32
ref_image:
image_width: 2508
ref_image.image_height
Indicate reference image height
Uint32
ref_image:
image_height: 625
Build application From Source#
  • Go to the folder sources/apps/sample_apps/deepstream-can-orientation-app.
  • Run the following commands:
    $ make
    $ make install
