Gst-nvimageenc#
The Gst-nvimageenc plugin encodes images on dGPU and (ARM + dGPU) platforms like arm-sbsa. This plugin is based on the libnvjpeg library which is part of the CUDA toolkit. The plugin accepts RGB input and produces JPEG encoded bitstream.
Inputs and Outputs#
  • Inputs
    • Gst Buffer in RGB format
  • Control parameters
    • gpu-id
  • Output
    • Gst Buffer with encoded output in JPEG format
Features#
The following table summarizes the features of the Gst-nvimageenc plugin.
Gst-nvimageenc plugin features#
Feature
Description
Release
Supports JPEG Encode
DS 6.4
Gst Properties#
The following table summarizes the Gst properties of the Gst-nvimageenc plugin.
Gst-nvimageenc plugin gst properties#
Property
Meaning
Type and Range
Example and Notes
Platforms
gpu-id
Device ID of GPU to use for encoding.
Integer, 0 to 4,294,967,295
gpu-id=0
dGPU, ARM+dGPU
