Implementing a Custom GStreamer Plugin with OpenCV Integration Example#
The DeepStream SDK supports a mechanism to add third party or custom algorithms within the reference application by modifying the example plugin (gst-dsexample). The sources for the plugin are in sources/gst-plugins/gst-dsexample directory in the SDK.
This plugin was written for GStreamer 1.14.1 but is compatible with newer versions of GStreamer. This plugin derives from the GstBaseTransform class:
https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gstreamer-libs/html/GstBaseTransform.html
Note
To enable OpenCV functionalities, compile dsexample plugin with flag WITH_OPENCV=1 in the plugin Makefile.
Description of the Sample Plugin: gst-dsexample#
The GStreamer example plugin (gst-dsexample) demonstrates the following:
Processing the entire frame, with downscaling / color conversion if required.
Processing objects detected by the Primary Detector, specifically, cropping these objects from the frame and then processing the crops.
In-place modification of the buffer frame contents using OpenCV
Two versions of the plugin are included. Refer to the plugin’s
Makefileand README to switch between themSimple (gstdsexample.cpp) - Sequential pre-processing and processing
Optimized (gstdsexample_optimized.cpp) - Parallel batch pre-processing and processing
This release includes a simple static library dsexample_lib that demonstrates the interface between custom libraries and this Gstreamer plugin. The library generates simple labels of the form Obj_label. The library implements these functions:
DsExampleCtxInit — Initializes the custom library
DsExampleCtxDeinit — De-initializes the custom library
DsExampleProcess – Process on an input frame
The GStreamer plugin itself is a standard in-place transform plugin. Because it does not generate new buffers but only adds / updates existing metadata, the plugin implements an in-place transform. Some of the code is standard GStreamer plugin boilerplate (e.g. plugin_init, class_init, instance_init). Other functions of interest are as follows:
GstBaseTransfrom Class Functions#
start — Acquires resources, allocate memory, initialize example library.
stop — De-initializes the example library and frees up resources and memory.
set_caps — Gets the capabilities of the video (i.e. resolution, color format, framerate) that flow through this element. Allocations/initializations that depend on input video format can be done here.
transform_ip — Implemented in the simple version. Called when the plugin receives a buffer from upstream element.
Finds the metadata of the primary detector.
Use
get_converted_matto pre-process frame/object crop to get the required buffer for pushing to library. Push the data to the example library. Pop the example library output.Attach/update metadata using
attach_metadata_full_frameorattach_metadata_object.Alternatively, modify frame contents in-place to blur objects using
blur_objects.
submit_input_buffer — Implemented in the optimized version. Called when the plugin receives a buffer from upstream element. Works in parallel with
gst_dsexample_output_loopto improve performance.Finds the metadata of the primary detector.
Create a batch of frames/objects to pre-process. Pre-process the batches and push the pre-processed output to the processing thread.
Pre-process on the next batch while the processing thread works on an older batch.
Other supporting functions#
get_converted_mat — Scales, converts, or crops the input buffer, either the full frame or the object based on its co-ordinates in primary detector metadata.
attach_metadata_full_frame — Shows how the plugin can attach its own metadata for objects detected by the plugin.
attach_metadata_object — Shows how the plugin can update labels for objects detected by primary detector.
blur_objects — Modify buffer frame contents in-place to blur objects using OpenCV GaussianBlur. When running on dGPU make sure that input memory type to plugin is
NVBUF_MEM_CUDA_UNIFIED.gst_dsexample_output_loop — Works in parallel with
submit_input_bufferto improve performance.Wait for pre-processing of a batch to finish
Process on the batch using
dsexample_libAPIsAttach the output using one of
attach_metadata\_*functions
Note
On Jetson devices, custom GStreamer plugins must export the environment variable DS_NEW_BUFAPI and set its value to 1. See gst_dsexample_class_init() for an example in a plugin (Gst-dsexample).
Enabling and configuring the sample plugin#
The pre-compiled deepstream-app binary already has the functionality to parse the configuration and add the sample element to the pipeline.
To enable and configure the plugin, add the following section to an existing configuration file (for example, source4_720p_dec_infer-resnet_tracker_sgie_tiled_display.txt):
[ds-example]
enable=1
processing-width=640
processing-height=480
full-frame=0
blur-objects=0
unique-id=15
Using the sample plugin in a custom application/pipeline#
The sample plugin can be used in a gst-launch pipeline. The pipeline can also be constructed in a custom application.
To construct a pipeline for running the plugin in full frame mode Construct a pipeline for running the plugin in full frame mode with the following command.
For Jetson:
$ gst-launch-1.0 filesrc location= <mp4-file> ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvvideoconvert ! dsexample full-frame=1 <other-properties> ! nvdsosd ! nv3dsink
For Tesla:
$ gst-launch-1.0 filesrc location= <mp4-file> ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvvideoconvert ! dsexample full-frame=1 <other-properties> ! nvdsosd ! nveglglessink
To construct a pipeline for running the plugin to process on objects detected by the primary model Construct a pipeline for running the plugin to process on objects detected by the primary model with the following command.
For Jetson:
$ gst-launch-1.0 filesrc location= <mp4-file> ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path= <primary-detector-config> ! nvvideoconvert ! dsexample full-frame=0 <other-properties> ! nvdsosd ! nv3dsink
For Tesla:
$ gst-launch-1.0 filesrc location= <mp4-file> ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path= <primary-detector-config> ! nvvideoconvert ! dsexample full-frame=0 <other-properties> ! nvdsosd ! nveglglessink
To construct a pipeline for running the plugin to blur objects detected by the primary model Construct a pipeline for running the plugin to blur objects detected by the primary model with the following command:
For Jetson:
$ gst-launch-1.0 filesrc location= <mp4-file> ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path= <primary-detector-config> ! nvvideoconvert ! 'video/x-raw(memory:NVMM), format=RGBA' ! dsexample full-frame=0 blur-objects=1 ! nvdsosd ! nv3dsink
For Tesla:
$ gst-launch-1.0 filesrc location= <mp4-file> ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path= <primary-detector-config> ! nvvideoconvert nvbuf-memory-type= nvbuf-mem-cuda-unified ! 'video/x-raw(memory:NVMM), format=RGBA' ! dsexample full-frame=0 blur-objects=1 ! nvdsosd ! nveglglessink
Implementing Custom Logic Within the Sample Plugin#
To implement custom logic within the plugin, replace the following function calls list below with corresponding functions of any other custom library.
DsExampleCtxInit
DsExampleCtxDeinit
DsExampleProcess
blur_objects
Depending on the input requirements of the library, get_converted_mat may also require modification.
Adding NVTX APIs for sample plugin#
Like other DeepStreamSDK GStreamer plugins, NVTX APIs can be added in a custom plugin as well. More information on these APIs can be found in https://docs.nvidia.com/gameworks/content/gameworkslibrary/nvtx/nvidia_tools_extension_library_nvtx.htm. Follow the steps below to add NVTX APIs for custom plugin:
Include
nvtx3/nvToolsExt.hheader in the source code of plugin.To measure range, two APIs are commonly used:
nvtxRangePushA (context)- Point at which profiling starts for this component / plugin.nvtxRangePop ()- Point at which profiling stops for this component / plugin.
Make sure the markers are placed such that the core functions of the plugin are performed between the above two APIs. This will give an accurate idea of latency.
Run NSight for the custom plugin to obtain information for the tasks run between these two markers.
Accessing NvBufSurface memory in OpenCV#
CUDA and CPU memory in NvBufSurface can be accessed through cv::cuda::GpuMat and cv::Mat interface of OpenCV respectively. In that case, NvBufSurface can work with any computer vision algorithm implemented in OpenCV.
Following code snippet shows how to access and use CUDA memory of NvBufSurface in OpenCV.
cv::cuda::GpuMat gpuMat;
const int aDstOrder[] = {2,0,1,3};
unsigned int index = 0; // Index of the buffer in the batch.
unsigned int width, height; // set width and height of buffer
NvBufSurface *input_buf; // Pointer to input NvBufSurface
gpuMat = cv::cuda::GpuMat(height, width, CV_8UC4,
(void *)input_buf->surfaceList[index].dataPtr);
OR
(void *) input_buf->surfaceList[index].dataPtr,
input_buf->surfaceList[index].pitch);
cv::cuda::swapChannels(gpuMat, aDstOrder);
On Jetson platform, if memory of NvBufSurface is of type NVBUF_MEM_SURFACE_ARRAY you should convert it to CUDA through CUDA-EGL interop before accessing it in OpenCV.
Refer to sources/gst-plugins/gst-dsexample/gstdsexample.cpp to access the NvBufSurface memory in OpenCV matrix (cv::Mat).
Below steps are required:
Create EGL image from NvBufSurface using NvBufSurfaceMapEglImage()
Register EGL image in cuda using cuGraphicsEGLRegisterImage()
Map EGL frame using cuGraphicsResourceGetMappedEglFrame() to get cuda pointer
Refer to gst_nvinfer_allocator_alloc in file /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvinfer/gstnvinfer_allocator.cpp for more details.
