Performance#
DeepStream application is benchmarked across various NVIDIA TAO Toolkit and open source models. The measured performance represents end-to-end performance of the entire video analytic application considering video capture and decode, pre-processing, batching, inference, and post-processing to generate metadata. The output rendering is turned off to achieve peak inference performance. For information on disabling the output rendering, see DeepStream Reference Application - deepstream-app chapter.
TAO Pre-trained models#
TAO toolkit has a set of pretrained models listed in the table below. If the models below satisfy your requirement, you should start with one of them. These could be used for various applications in smart city or smart places. If your application is beyond the scope of these models, you may re-train one of the popular model architecture using TAO toolkit. The table below shows the end-to-end performance on highly accurate pre-trained models from TAO toolkit. All models are available on NGC. These models are natively integrated with DeepStream and the instructions to run these models are in /opt/nvidia/deepstream/deepstream/samples/configs/tao_pretrained_models/. The following numbers are obtained with sample_1080p_h265.mp4.
Performance jetson- pretrained models#
Jetson
Thor
Model Arch
Inference resolution
Precision
Tracker
GPU
(FPS)
C-RADIO-B
3*224*224
FP16
No Tracker
1258
C-RADIO-L
3*224*224
FP16
No Tracker
547
NV-DinoV2-L
3*224*224
FP16
No Tracker
431
RT-DETR
3*640*640
FP16
No Tracker
195
RT-DETR
3*640*640
FP16
NvDCF Tracker
171
RT-DETR
3*640*640
FP16
MV3DT Tracker
90
Peoplenet 2.6.3
3*640*640
FP16
MV3DT Tracker
363
Grounding-DINO
3*544*960
FP16
No Tracker
23
TrafficCamnet Transformer Lite
3*544*960
FP16
NvDCF Tracker
144
SegFormer
3*640*640
FP16
No Tracker
253
Mask2Former + SWIN
3*800*800
FP16
No Tracker
26
Performance dgx-spark - pretrained models#
DGX
Spark
Model Arch
Precision
Tracker
GPU
(FPS)
C-RADIO-B
3*224*224
FP16
No Tracker
969
C-RADIO-L
3*224*224
FP16
No Tracker
337
NV-DinoV2-L
3*224*224
FP16
No Tracker
239
RT-DETR
3*640*640
FP16
No Tracker
160
RT-DETR
3*640*640
FP16
NvDCF Tracker
153
RT-DETR
3*640*640
FP16
MV3DT Tracker
89
Peoplenet 2.6.3
3*640*640
FP16
MV3DT Tracker
350
Grounding-DINO
3*544*960
FP16
No Tracker
21
3*544*960
FP16
NvDCF
139
SegFormer
3*640*640
FP16
No Tracker
201
Mask2Former + SWIN
3*800*800
FP16
No Tracker
29
Performance dgpu- pretrained models#
RTX 4500
PRO 6000 WS
PRO 6000 SE
L40s
B200
GB200
Model Arch
Precision
Inference Engine
Tracker
GPU (FPS)
GPU (FPS)
GPU (FPS)
GPU (FPS)
GPU (FPS)
GPU (FPS)
C-RADIO-B
3*224*224
FP16
TRT
No Tracker
2050
4131
3754
2989
8586
9531
C-RADIO-L
3*224*224
FP16
TRT
No Tracker
647
1497
1303
1097
3664
4077
NV-DinoV2-L
3*224*224
FP16
TRT
No Tracker
533
1292
1173
873
3626
3594
RT-DETR
3*640*640
FP16
TRT
No Tracker
345
659
978
649
1328
1405
RT+DETR
3*640*640
FP16
TRT
NvDCF Tracker
316
640
955
615
1298
1395
RT+DETR
3*640*640
FP16
TRT
MV3DT Tracker
257
645
537
237
932
1010
Peoplenet 2.6.3
3*640*640
FP16
TRT
MV3DT Tracker
595
1225
763
724
2971
3224
Grounding-DINO
3*544*960
FP16
TRT
No Tracker
63
103
102
101
219
230
TrafficCamNet Transformer Lite
3*544*960
FP16
TRT
NvDCF Tracker
369
650
918
665
1138
1180
SegFormer
3*640*640
FP16
TRT
No Tracker
435
1236
1061
1008
1320
1348
Mask2Former + SWIN
3*800*800
FP16
TRT
No Tracker
70
75
99
76
118
188
MaskGroundingDINO V2
3*544*960
FP16
TRT
No Tracker
63
102
101
102
220
230
TAO Fine-tuned models#
TAO Toolkit Finetuning Microservice provides a new interface for accelerating model training and automating model fine-tuning flows. The fine-tuned models can be used by DeepStream SDK 9.0 out-of-the-box via Inference Builder. The table mentioned in the TAO Pre-trained models section shows the end-to-end performance on fine-tuned models from TAO toolkit.
DeepStream reference model and tracker#
DeepStream SDK ships with a reference DetectNet_v2-ResNet10 model and three ResNet18 classifier models. The detailed instructions to run these models with DeepStream are provided in the next section. DeepStream provides four reference trackers: IOU, NvSORT, NvDeepSORT and NvDCF. For more information about trackers, See the Gst-nvtracker section.
Configuration File Settings for Performance Measurement#
To achieve peak performance, make sure the devices are properly cooled. For Turing and Ampere GPUs, make sure you use a server that meets the thermal and airflow requirements. Along with the hardware setup, a few other options in the config file need to be set to achieve the published performance. Make the required changes to one of the config files from DeepStream SDK to replicate the peak performance.
Turn off output rendering, OSD, and tiler
OSD (on-screen display) is used to display bounding box, masks, and labels on the screen. If output rendering is disabled, creating bounding boxes is not required unless the output needs to be streamed over RTSP or saved to disk. Tiler is used to display the output in NxM tiled grid. It is not needed if rendering is disabled. Output rendering, OSD and tiler use some percentage of compute resources, so it can reduce the inference performance.
To disable OSD, tiled display and output sink, make the following changes in the DeepStream config file.
  • To disable OSD, change enable to 0
    [osd]
    enable=0
  • To disable tiling, change enable to 0
    [tiled-display]
    enable=0
  • To turn-off output rendering, change the sink to fakesink.
    [sink0]
    enable=1
    #Type - 1=FakeSink 2=EglSink 3=File
    type=1
    sync=0
Use the max_perf setting for tracker
DeepStream SDK 6.2 onwards introduces a new reference low-level tracker library, NvMultiObjectTracker, along with a set of configuration files:
  • config_tracker_IOU.yml
  • config_tracker_NvDCF_max_perf.yml
  • config_tracker_NvDCF_perf.yml
  • config_tracker_NvDCF_accuracy.yml
To achieve the peak performance shown in the table above when using the NvDCF tracker, make sure the max_perf configuration is used with video frame resolution matched to that of the inference module. If the inference module uses 480x272 resolution, for example, it would be recommended to use a reduced resolution (e.g., 480x288) for the tracker module like the following:
[tracker]
enable=1
tracker-width=480
tracker-height=288
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
#ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_IOU.yml
ll-config-file=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_max_perf.yml
gpu-id=0
enable-batch-process=1
display-tracking-id=1
When the IOU tracker is used, the video frame resolution doesn’t matter, and the default config_tracker_IOU.yml can be used.
CudaDeviceScheduleBlockingSync flag is set by default on dGPU
  • On dGPU only, cudaDeviceScheduleBlockingSync flag is set by default on the GPU where the Deepstream pipeline runs. In general, for pipelines with multiple streams, this helps in reducing the CPU utilization without affecting the performance much.
  • Setting cudaDeviceScheduleBlockingSync flag when sub batches are enabled in the tracker, results in significant reduction in CPU utilization with similar or negligible dip in performance.
  • When the environment variable NVDS_DISABLE_CUDADEV_BLOCKINGSYNC is set to 1, cudaDeviceScheduleBlockingSync flag is not set by default.
  • There is a remote possibility that setting cudaDeviceScheduleBlockingSync flag might affect the pipeline performance negatively when the pipeline already runs with GPU utilization close to 100%. Hence, when the user encounters a situation where a Deepstream pipeline is GPU bound and the GPU utilization does not reach close to 100%, then the user may experiment with setting NVDS_DISABLE_CUDADEV_BLOCKINGSYNC to 1 and check if it helps in improving the performance of the pipeline.
