Gst-nvdsaudiotemplate#
The OSS Gst-nvdsaudiotemplate plugin is a template plugin which provides a custom library hooking interface for single/batched audio frame(s) processing. Custom lib implementation may have algorithms to transform or process input buffers depending upon the use case. It can support S16LE and F32LE inputs. The plugin accepts batched NVMM HW and RAW SW buffers, and outputs batched HW and SW buffers.
Inputs and Outputs#
Inputs
NVMM or RAW Gst Buffers. Supported formats are S16LE and F32LE
Control parameters
customlib-name
gpu-id
customlib-props
Output
Transformed Gst Buffer
Features#
Gst-nvdsaudiotemplate features# Feature
Description
Release
Simplified APIs
Simplified interface to implement custom library to add any algorithm without implementing new plugin
DS 5.1
Easy Data Accessing
Easy access to GstBuffer and it’s metadata inside custom library
DS 5.1
Synchronous and Asynchronous Buffer Processing
Buffer_Ok is the responsibility of the plugin to push the buffer downstream.
Buffer_Async is the responsibility of the custom library to push the buffer downstream.
Buffer_Error and Buffer_Drop are currently not implemented
DS 5.1
Reference Impl.
Reference implementation of custom library provides transform, transform-ip, metadata handling etc. which can be modified as per the use case.
DS 5.1
Abstraction APIs
Bufferpool creation, caps handling provided as an abstraction API inside customlib base class
DS 5.1
customlib_impl Interfaces#
SetInitParams
- Based on the negotiated caps, this API creates output buffer pool of the negotiated resolutionHandleEvent
- This API handles standard Gstreamer events as well as custom events such as PAD_ADDED PAD_DELETED etc.GetCompatibleCaps
- This API returns the fixated caps to be set on either SINK / SRC pad of the pluginProcessBuffer
- This API passes the GstBuffer to customlib for further processingSetProperty
- This API sets the customlib properties that are used by the underlying library for processing
Gst Properties#
The following table describes the Gst properties of the Gst-nvdsaudiotemplate plugin.
Gst-nvsaudiotemplate gst properties# Property
Meaning
Type and Range
Example/Notes
Platforms
gpu-id
Device ID of GPU to use for decoding.
Integer, 0 to 4,294,967,295
gpu-id=0
dGPU
customlib-name
custom library Name to be used
String
Default: null
dGPU
customlib-props
Custom Library Properties (key:value) string, can be set multiple times,vector is maintained internally
String
Default: null
dGPU
Sample pipelines#
For single stream:
gst-launch-1.0 audiotestsrc wave=0 num-buffers=1000 ! audioconvert ! nvdsaudiotemplate \
customlib-name="libcustom_impl.so" customlib-props="noise-factor:100" ! \
wavenc ! filesink location=audio.wav buffer-mode=2
For Multi-stream (Ensure that new nvstreammux is enabled):
export USE_NEW_NVSTREAMMUX=yes
gst-launch-1.0 audiotestsrc wave=0 ! audioconvert ! m.sink_0 nvstreammux name=m \
! nvdsaudiotemplate customlib-name="libcustom_impl.so" customlib-props="noise-factor:10" ! nvstreamdemux name=d d.src_0 \
! wavenc ! filesink location=audio.wav buffer-mode=2 audiotestsrc wave=1 ! audioconvert ! m.sink_1
