Gst-nvds3dbridge#
The Gst-nvds3dbridge plugin is a customizable plugin which provides a custom library interface to load component ds3d::databridge
The Plugin is fully configured through YAML format content or file. sink_caps
and src_caps
is also configurable.
Note
Support for 3D (DS3D data format) to 2D (video/x-raw NVMM) is not provided.
Gst-nvds3dbridge properties Specifications#
Properties |
Description |
Release |
config-content |
yaml config content |
DS 7.0 |
config-file |
yaml config file path |
DS 7.0 |
Custom library Interfaces#
The plugin parse the config file or content and set SinkCaps and SrcCaps. load a custom ds3d::databridge
from custom_lib_path
. Create this databridge by custom_create_function
Supported DS3D Data bridges#
SL |
Data bridge |
Data bridge custom library |
1 |
Video data bridge; wraps NVMM video memory to ds3d/datamap |
Custom low level library: libnvds_3d_video_databridge.so
Inputs and Outputs#
Inputs
video/x-raw(memory:NVMM)
data format: NvBufSurface
with/without GStreamer metadata (including NvDsBatchMeta)
Control parameters
config-file
config-content
Output
ds3d/datamap
sink_caps
parsed from config-file:
in_caps: video/x-raw(memory:NVMM)
src_caps
out_caps:
ds3d/datamap.
Configuration file#
- Example:
name: videobridge_2d_to_3d type: ds3d::databridge in_caps: video/x-raw(memory:NVMM) out_caps: ds3d/datamap custom_lib_path: libnvds_3d_video_databridge.so custom_create_function: createVideoBridge2d3d config_body: surface_to_image: True # wrap nvbufsurface into color frame of ds3d::Frame2DGuard output_image_key: DS3D::ColorFrame # convert NvDsObjectMeta into array of ds3d::Object2DBbox with ds3d::FrameGuard output_object2d_key: DS3D::Object2DBboxKey
Video bridge configuration options#
config-key |
Description |
Example value |
surface_to_image |
True / False |
output_image_key |
The key name to use when generating datamap output. This name will be used to configure the input of downstream ds3d component. |
DS3D::ColorFrame |
output_object2d_key |
The key name to use when generating datamap output. This key name will be used to save NvDsObjectMeta from NvDsBatchMeta as an array of ds3d::Object2DBbox. |
DS3D::Object2DBboxKey |
