DeepStream On WSL#
Windows Subsystem for Linux (WSL) is a feature of Windows that allows you to run a Linux environment on your Windows machine, without the need for a separate virtual machine or dual booting. WSL 2 is the latest version of it. This page describes the steps to run a Deepstream docker container inside WSL2.
Pre-Requisites:#
1. Windows 11 system with NVIDIA GPU:
NOTE: Tesla/Datacenter GPUs are not supported for WSL. Only GeForce and Quadro GPUs in WDDM mode are supported. Please check the link for more info: https://docs.nvidia.com/cuda/wsl-user-guide/index.html#wsl-2-support-constraints
2. NVIDIA driver (windows version) compatible for your GPU:
You can download the compatible driver based on your windows OS and GPU type from here: https://www.nvidia.com/Download/index.aspx
Currently validated Driver Version and GPU info: GameReady Driver version 546.65 with RTX-3080, RTX-3090 and RTX-A6000
NOTE: This is the only driver you need to install on Windows. Do not install any Linux display driver inside WSL.
3. WSL (Windows Store Version):
Download and install the latest stable version of WSL2 from microsoft/WSL.
NOTE: In some build versions of Windows, ‘wsl –install’ command will install the WSL which comes as a part of windows image, which has limited functionality. DO NOT install that.
Install Ubuntu OS for WSL :#
Open terminal and install Ubuntu 22:
Open windows terminal with admin privilege. (Right click and run as administrator) Check what all OS images are available for wsl to install.
$ wsl --list --online
Install Ubuntu version required for Deepstream 7.1.
$ wsl --install Ubuntu-22.04
The above step may first install dependencies for running WSL, prior to install Ubuntu and can ask for restart of Windows machine. In that case, restart the machine, open windows terminal with admin privilege and check if Ubuntu is installed properly using below command.
$ wsl --list
If you can’t find an installed Ubuntu version, again install it using ‘wsl –install Ubuntu-22.04’ command. Set the username and password for Ubuntu when prompted.
Install Docker Engine And Dependencies Inside Ubuntu:#
Start Ubuntu Inside WSL:
Open windows terminal with admin privilege (Right click and run as administrator).
Start Ubuntu using WSL. (This step is required only if you are not already logged into Ubuntu)
$ wsl -d Ubuntu-22.04
Verify Driver Installation from within WSL environment:
$ nvidia-smi
NOTE: If ‘nvidia-smi’ is not working as expected, then there is some issue with the driver installation in windows and we can’t go further without fixing this.
Install Docker Engine and Dependencies:
$ sudo apt-get update
$ sudo apt-get install -y apt-transport-https ca-certificates curl gnupg-agent software-properties-common
$ curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
$ sudo apt-key fingerprint 0EBFCD88
$ sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
$ sudo apt-get install -y docker-ce docker-ce-cli containerd.io --fix-missing
Verify docker installation:
This should print a “Hello from Docker!”
$ sudo docker run hello-world
NOTE: If you are not able to run the above command because of docker service not running, start the docker service before that.
$ sudo dockerd &
Enabling the Docker Repository and Installing the NVIDIA Container Toolkit:
$ distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
$ curl -fsSL https://nvidia.github.io/libnvidia-container/gpgkey | sudo gpg --dearmor -o /usr/share/keyrings/nvidia-container-toolkit-keyring.gpg
$ curl -s -L https://nvidia.github.io/libnvidia-container/$distribution/libnvidia-container.list | sed 's#deb https://#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://#g' | sudo tee /etc/apt/sources.list.d/nvidia-container-toolkit.list
$ sudo apt-get update && sudo apt-get install -y nvidia-container-toolkit
$ sudo systemctl restart docker
Run Deepstream Container:#
Pull the required deepstream docker container:
$ sudo docker pull nvcr.io/nvidia/deepstream:7.1-triton-multiarch
Start the docker container:
$ sudo apt install x11-xserver-utils
$ xhost +
$ sudo docker run -it --privileged --rm --name=docker --net=host --gpus all -e DISPLAY=$DISPLAY -e CUDA_CACHE_DISABLE=0 --device /dev/snd -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:7.1-triton-multiarch
Verify deepstream functionality:
$ deepstream-app --version
Expected Output: It should print the deepstream version currently installed on docker.
$ cd /opt/nvidia/deepstream/deepstream/samples/streams
$ gst-launch-1.0 filesrc location= sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nveglglessink -v
Expected Output: Playback of the sample_720p.mp4 should happen fine. Sample screenshot attached below:
NOTE: The display window size may differ in different systems based on the screen resolution supported. You can drag and adjust the display window to fit your screen.
$ cd /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app
$ deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
Expected Output: deepstream-app should run fine. Sample screenshot attached below:
Note
