Gst-nvurisrcbin#
1. Introduction#
This GstBin is a GStreamer source bin. This bin is a wrapper over uridecodebin with additional functionality of the file looping, rtsp reconnection and smart record.
The bin allows users to create simple gstreamer pipelines for AI multimedia analytics.
For more details on nvurisrcbin, please run gst-inspect-1.0 nvurisrcbin on a machine/docker container with DeepStream installed.
2. How to use nvurisrcbin in a pipeline#
Below pipeline is a sample gstreamer pipeline which is configured to accept input source:
gst-launch-1.0 nvurisrcbin \
uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! \
m.sink_0 nvstreammux name=m width=1280 height=720 batch-size=1 ! nvmultistreamtiler ! nveglglessink
3. Gst Properties#
3.1 Gst Properties to configure nvurisrcbin#
Gst-nvurisrcbin specific properties#
Property
Meaning
Type and Range
Example Notes
num-extra-surfaces
Set extra decoder surfaces; Number of surfaces in addition to minimum decode surfaces given by the decoder
Integer, 1 to 4,294,967,295
num-extra-surfaces=1 (default)
gpu-id
Set GPU Device ID used by nvurisrcbin components like decoder (nvv4l2decoder) and nvvideoconvert
gpu-id=0 (default)
cudadec-memtype
Memory type for cuda decoder buffers, Memory type for CUDA decoder buffers. Represented internally by enum CudaDecMemType. 0 (memtype_device): Device 1 (memtype_pinned): Host Pinned 2 (memtype_unified): Unified
Integer, 0, 1, or 2
cudadec-memtype=0 (default)
drop-frame-interval
Interval to drop the frames, e.g. a value of 5 means the decoder outputs every fifth frame, and others are dropped.
Integer, 1 to 30
Default: 0, dGPU / Jetson
dec-skip-frames
Type of frames to skip during decoding. Represented internally by enum SkipFrame. 0 (decode_all): decode all frames 1 (decode_non_ref): skips non-ref frames (Applicable only on Jetson platform) 2 (decode_key): decode key frames
Integer, 0, 1, or 2
skip-frames=0 Default: 0 ,dGPU / Jetson
select-rtp-protocol
Transport Protocol to use for RTP
Enum RtpProtocol Default: 0, rtp-multi (0): rtp-multi - UDP + UDP Multicast + TCP (4): rtp-tcp - TCP Only
select-rtp-protocol=0 (default)
file-loop
Loop file sources after EOS. Src type must be source-type-uri and uri starting with ‘file:/
boolean
file-loop=false (default)
rtsp-reconnect-interval
Timeout in seconds to wait since last data was received from an RTSP source before forcing a reconnection. 0=disable timeout
rtsp-reconnect-interval=10
rtsp-reconnect-attempts
Maximum number of times a reconnection is attempted. Setting it to -1 means reconnection will be attempted infinitely. Valid when type of source is 4 and rtsp-reconnect-interval-sec is a non-zero positive value.
Integer, >=-1
rtsp-reconnect-attempts=4
latency
Jitterbuffer size in milliseconds; applicable only for RTSP streams.
latency=100 (default)
udp-buffer-size
UDP Buffer Size in bytes; applicable only for RTSP streams.
udp-buffer-size=524288 (default)
smart-record
Enable Smart Record and choose the type of events to respond to. Sources must be of type source-type-rtsp
(0):smart-rec-disable - Disable Smart Record (1):smart-rec-cloud  - Trigger Smart Record through cloud messages only (2):smart-rec-multi  - Trigger Smart Record through cloud and local events
smart-record=0 (default)
smart-rec-dir-path
Path of directory to save the recorded file.
string
Absolute or relative path
smart-rec-file-prefix
By default, Smart_Record is the prefix. For unique file names every source must be provided with a unique prefix
string
smart-rec-video-cache
Size of video cache in seconds. DEPRECATED: Use ‘smart-rec-cache’ instead
smart-rec-video-cache=0 (default)
smart-rec-cache
Size of cache in seconds, applies to both audio and video cache
smart-rec-cache=0 (default)
smart-rec-container
Container format of recorded video. MP4 and MKV containers are supported. Sources must be of type source-type-rtsp
(0): smart-rec-mp4 - MP4 container (1): smart-rec-mkv - MKV container
smart-rec-container=0 (default)
smart-rec-mode
Smart record mode
(0):smart-rec-mode-av - Record audio and video if available (1):smart-rec-mode-video - Record video only if available (2):smart-rec-mode-audio - Record audio only if available
smart-rec-mode=0 (default)
smart-rec-default-duration
In case a Stop event is not generated. This parameter will ensure the recording is stopped after a predefined default duration.
smart-rec-default-duration=20 (default)
async-handling
Boolean property so that will handle Asynchronous state changes
boolean
async-handling=true(default)
disable-audio
Disable audio path mode at init time
boolean
disable-audio=true(default)
ipc-buffer-timestamp-copy
Copy buffer timestamp for nvunixfdsrc plugin
boolean
ipc-buffer-timestamp-copy=false(default)
ipc-connection-attempts
Max number of attempts for connection (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
ipc-connection-attempts=-1(default)
ipc-connection-interval
connection interval between connection attempts in micro seconds
Unsigned Integer64. Range: 0 - 18446744073709551615
ipc-connection-interval=1000000(default)
ipc-socket-path
The path to the control socket used to control the shared memory transport. This may be modified during the NULL->READY transition
String
ipc-socket-path=null(default)
low-latency-mode
Set low latency mode for bitstreams having I and IPPP frames on decoder
boolean
low-latency-mode=false(default)
drop-on-latency
Tells the jitterbuffer to never exceed the given latency in size
boolean
drop-on-latency=true(default)
message-forward
Forwards all children messages
boolean
message-forward=false(default)
