Gst-nvdsasr#
The Gst-nvdsasr
plugin performs automatic speech recognition (ASR) on the input audio data.
The plugin provides a mechanism to load custom ASR low level library at runtime.
It is supported on both x86 and Jetson platforms and can be used on x86, Jetson devices or from inside DeepStream dockers.
A custom library libnvds_riva_asr_grpc.so
is provided which uses gRPC APIs to access the Riva ASR service.
The library communicates with the ASR service of the NVIDIA Riva SDK for speech recognition and punctuation-capitalization using optimized Riva models.
Note
The DS-Riva ASR library,
, uses gRPC APIs to access the Riva ASR service. The Riva ASR service should be started before using this library. Required steps are outlined below in section ‘Riva ASR Service Deployment’.Installation of the gRPC C++ libraries (v1.38) is required on the client side. Required steps are outlined below in section ‘gRPC C++ Library Installation’.
Note
The libnvds_riva_asr_grpc.so
library works with NVIDIA Riva Release 1.5.0 Beta or later.
The plugin accepts raw PCM audio GStreamer buffers (GstBuffer
) from upstream component. It transforms audio into generic text GstBuffer
output.
Model needs raw audio data input with S16LE (Signed 16bit Little Endian). Library settings can be configured via YAML format file (by setting a property on Gst-nvdsasr
plugin) which has multi-part settings for plugin.
As shown in the diagram below input S16LE raw audio data is preprocessed and inferred by the Riva ASR service . The final output is available in UTF8 text.
Inputs and Outputs#
This section summarizes the inputs, outputs, and communication facilities of the Gst-nvdsasr
plugin with the gRPC based ASR library.
Input
Raw Audio GStreamer buffers
Control parameters
customlib-name
: Set a custom ASR library that the plugin loads to perform inference. Use :libnvds_riva_asr_grpc.so
create-speech-ctx-func
: Symbol name to create ASR speech context. Use :create_riva_asr_grpc_ctx
config-file
: A text file to configure the plugin. Useriva_asr_grpc_conf.yml
Outputs
Text GStreamer buffer containing ASR output
Features#
Feature |
Description |
Release |
Speech ASR template |
The plugin is a ASR speech base which can support custom ASR library loading in runtime |
DS 6.0 |
Live stream transcription |
Support partial transcript output in realtime |
DS 6.0 |
Final transcription |
Support final transcription only useful for local audio streams |
DS 6.0 |
Languages support |
The plugin is currently only tested for English (en-US) |
DS 6.0 |
Words punctuation |
Support words punctuation and capitalization |
DS 6.0 |
Custom library with gRPC API implementation |
Supports custom library implementation that uses gRPC APIs for accessing Riva ASR gRPC service. Set |
DS 6.0 |
x86 platform support |
DS 6.0 |
Jetson platform support |
DS 6.2 |
DS-Riva ASR Library YAML File Configuration Specifications#
DS-Riva ASR configuration file uses YAML 1.2 file format: https://yaml.org/spec/1.2/spec.html.
There are multiple parts in the config file. An example for the gRPC
yml file is located at/opt/nvidia/deepstream/deepstream/sources/apps/audio_apps/deepstream_asr_tts_app/
. Each part has aname
indicating a unique part name and adetail
indicating the setting details.name: riva_server
part configures Riva ASR server settings in its corresponding nodedetail:
.name: riva_model
part configures Riva ASR model entry in its corresponding nodedetail:
.name: riva_asr_stream
part configures Riva low level library supported features in its corresponding nodedetail:
. Each ASR plugin instance will launch a standalone Riva stream. The settings between different plugin instances could be different.name: ds_riva_asr_plugin
part configures DS-Riva ASR settings in its corresponding nodedetail:
.A separator line with
is inserted between the 2 neighbor parts according to YAML specification.
Gst Properties#
The following tables describes the Gst
properties of the Gst-nvdsasr
plugin.
Property |
Meaning |
Type and Range |
Example Notes |
name |
Unique name |
String |
detail |
Node for Riva Server Setting details |
Node |
detail: server_uri: “localhost:50051” |
server_uri |
Part of detail node. Specify Riva ASR service address. Used in case of gRPC APIs. |
String |
Property |
Meaning |
Type and Range |
Example Notes |
name |
Unique name |
String |
Must be name: riva_model |
detail |
Node for Riva model setting details |
Node |
detail: model_name: citrinet-1024-asr-trt-ensemble-vad-streaming |
model_name |
Part of detail node. Specify which model entry is used |
String |
Property |
Meaning |
Type and Range |
Example Notes |
name |
Unique name |
String |
Must be name: riva_asr_stream |
detail |
Node for Riva ASR Steam setting details |
Node |
detail: encoding: LINEAR_PCM … |
encoding |
Part of detail node. Specify Input data format Only Value LINEAR_PCM is supported |
String |
encoding: LINEAR_PCM |
sample_rate_hertz |
Part of detail node. Input audio sample rate Only Value 16000 is supported |
Integer & >0 |
sample_rate_hertz: 16000 |
language_code |
Part of detail node. Specify which language is used for recognition Only Value en-US is supported |
String |
language_code: en-US |
max_alternatives |
Part of detail node. Max alternatives selected by top confidence Only 1 is supported at present |
Integer & >0 |
max_alternatives: 1 |
enable_automatic_punctuation |
Part of detail node. Enable automatic punctuation or not |
Boolean |
enable_automatic_punctuation: false |
Property |
Meaning |
Type and Range |
Example Notes |
name |
Unique name |
String |
Must be name: ds_riva_asr_plugin |
detail |
Node DS-Riva ASR library details |
Node |
detail: final_only: false |
final_only |
Part of detail node. Specify whether final transcriptions only or with partial transcription output together |
Boolean |
final_only: false |
enable_text_pts |
Part of detail node. Specify whether text buffer timestamp is enabled or not. |
Boolean |
enable_text_pts: false |
use_riva_pts |
Part of detail node. Specify whether time informatation provided by Riva service is used to calculate the timestamp and duration of output buffer. Note: At present this option is supported for non-live sources only |
Boolean |
use_riva_pts: false |
force_final_trailing |
Part of detail node. Enable insertion of new line character after the final transcription |
Boolean |
force_final_trailing: false |
Riva ASR Service Deployment#
Please check https://docs.nvidia.com/deeplearning/riva/user-guide/docs/quick-start-guide.html for the steps to deploy the models using Riva Quick start scripts:
Example steps to deploy Riva server with desired ASR model:
Download Riva Quick Start package:
$ ngc registry resource download-version nvidia/riva/riva_quickstart:1.5.0-beta $ cd riva_quickstart_v1.5.0-beta
Update config.sh file for required ASR model e.g CitriNet-1024:
service_enabled_asr=true service_enabled_nlp=false service_enabled_tts=false riva_model_loc="riva-asr-model-repo" models_asr=( "${riva_ngc_org}/${riva_ngc_team}/rmir_asr_citrinet_1024_asrset1p7_streaming:${riva_ngc_model_version}" "${riva_ngc_org}/${riva_ngc_team}/rmir_nlp_punctuation_bert_base:${riva_ngc_model_version}" )
Run the Riva initialization script:
$ bash riva_init.sh
Deploy the Riva ASR service:
$ bash riva_start.sh
To stop ASR services after the application has run successfully, run the following command:
$ bash riva_stop.sh
gRPC C++ Library Installation#
gRPC C++ shared libraries v1.38 installation is needed for the DS-Riva ASR library to access the Riva ASR gRPC service.
To install the libraries, please follow steps given at https://grpc.io/docs/languages/cpp/quickstart/ , and add -DBUILD_SHARED_LIBS=ON
to the cmake build options. (Recommended to use make -j4
instead of make -j
Or
Use the included script to install gRPC C++ libraries, this scripts performs same steps:
$ cd /opt/nvidia/deepstream/deepstream/sources/apps/audio_apps/deepstream_asr_app
$ sudo chmod +x gRPC_installation.sh
$ ./gRPC_installation.sh
Please run below command to add the installation path to the LD_LIBRARY_PATH environment variable:
$ export LD_LIBRARY_PATH=$HOME/.local/lib:$LD_LIBRARY_PATH
The gRPC C++ libraries are pre-installed on the DeepStream dGPU docker images. In the dGPU docker container, please run below command to add the installation path to the LD_LIBRARY_PATH environment variable:
Sample Test Application#
For information about Gst-nvdsasr
sample tests, please see source code under directory sources/apps/audio_apps/deepstream_asr_app.
Follow README
to run the sample tests.
