8.0 Release
- n -
n_label_outputs :
NvDsGieConfig
n_labels :
NvDsGieConfig
n_pts :
PolyFillCommand
name :
_FactoryMetadata
deepstream::SignalHandler::Callback
ds3d::config::ComponentConfig
mg_header
mg_option
NvDsFaceObject
NvDsFaceObjectWithExt
nvdsinferserver::InferBufferDescription
nvdsinferserver::LayerDescription
NvDsPlaceObject
name_ :
deepstream::Pipeline::StateTransitionMessage
nb_subprotocols :
mg_websocket_subprotocols
nChunks :
_GstNvDsUdpSink
ndim :
ds3d::v2xinfer::Tensor
needs_pool :
_GstNvImageDec
netInputOrder :
_NvDsInferContextInitParams
network_color_format :
NvDsPreProcessPropertySet
NvDsPreProcessTensorParams
network_height :
_GstNvInfer
network_info :
_GstNvInfer
NvDsInferTensorMeta
network_input_order :
network_input_shape :
network_width :
_GstNvInfer
networkInputFormat :
networkMode :
nvdsinfer::BuildParams
networkScaleFactor :
networkSize :
CustomMeanSubandNormParams
networkType :
_NvDsPostProcessContextInitParams
new_api :
NvDsSinkMsgConvBrokerConfig
new_state_ :
newAPI :
_GstNvMsgBroker
newConnHandle :
_GstNvMsgBroker
newLastError :
_GstNvMsgBroker
nextChunk :
_GstNvDsUdpSink
nextReadyFrameNo :
RoiProcessedBuf
nmsIOUThreshold :
NvDsInferDetectionParams
NvDsPostProcessDetectionParams
no_pipeline_eos :
_GstNvStreamMux
GstDsNvStreammuxConfig
NvDsStreammuxConfig
ntp_calc_mode :
_GstNvStreamMux
ntp_time_epoch_ns :
_NtpData
ntp_timestamp :
_NvDsAudioFrameMeta
_NvDsFrameMeta
ntp_ts :
GstBufferWrapper
ntpTimestamp :
NvBufAudioParams
num :
deepstream::VideoStreamInfo
num_aisle_views :
_Gstnvdewarper
num_arrows :
_GstNvDsOsd
_NvOSD_FrameArrowParams
NvDsDisplayMeta
num_batch_buffers :
_Gstnvdewarper
_GstNvDsAudioTemplate
_GstNvDsVideoTemplate
NvDsDewarperConfig
num_bins :
NvDsSinkBin
NvDsSrcParentBin
num_blurs :
_GstNvDsOsd
num_channels :
_NvDsAudioFrameMeta
num_children :
NvDsSecondaryGieBinSubBin
NvDsSecondaryPreProcessBinSubBin
num_circles :
_GstNvDsOsd
_NvOSD_FrameCircleParams
NvDsDisplayMeta
num_class_entries :
_GstNvDsOsd
num_classes :
_NvDsLabelInfo
_NvOSD_Ctx
bevfusion::decoder::Decoder::DecoderParameter
num_congestions :
NvDsEventMsgMeta
num_conversations :
NvDsLLMObject
num_coordinates :
NvDsInteractionObject
NvDsTypeMetricsObject
num_decode_surfaces :
NvDsSourceConfig
num_embeddings :
NvDsLLMObject
num_empty_elements :
_NvDsMetaPool
num_extra_surfaces :
_GstDsNvUriSrcConfig
NvDsSourceConfig
num_filled_surfaces :
_NvDewarperSurfaceMeta
num_fov :
NvDsEventMsgMeta
num_fr_on :
NvDsSrcParentBin
num_frames_in_batch :
_NvDsBatchMeta
num_full_elements :
_NvDsMetaPool
num_functions :
_NvDsNmosAssetConfig
num_headers :
mg_request_info
mg_response_info
num_host_addresses :
_NvDsNmosNodeConfig
num_instances :
NvDsAppPerfStruct
NvDsAppPerfStructInt
num_interactions :
NvDsEventMsgMeta
num_joints :
NvDsJoints
num_key_points :
NvDsPostProcessBodyPoseOutput
num_labels :
_NvDsClassifierMeta
NvDsDisplayMeta
num_lines :
_GstNvDsOsd
_NvOSD_FrameLineParams
NvDsDisplayMeta
num_local_interfaces :
_GstNvDsUdpSrc
num_log_categories :
_NvDsNmosNodeConfig
num_matches :
mg_match_context
num_message_consumers :
NvDsConfig
num_obj_meta :
_NvDsFrameMeta
num_objectIds :
NvDsCongestionObject
num_objects :
_NvDsBbox3dObjectList
num_operate_on_class_ids :
NvDsGieConfig
num_out_buffers :
NvDsDewarperConfig
NvDsOSDConfig
num_output_buffers :
_Gstnvdewarper
num_output_layers :
NvDsInferTensorMeta
num_planes :
NvBufSurfaceMapParams
NvBufSurfacePlaneParams
num_poses :
NvDsPersonPoseExt
num_receivers :
_NvDsNmosNodeConfig
num_rect :
_GstNvDsOsd
num_rects :
_NvOSD_FrameRectParams
NvDsDisplayMeta
num_rtsp_reconnects :
NvDsSrcBin
num_samples_per_frame :
_NvDsAudioFrameMeta
num_secondary_gie_sub_bins :
NvDsConfig
num_secondary_preprocess_sub_bins :
NvDsConfig
num_segments :
_GstNvDsOsd
_NvOSD_FrameSegmentMaskParams
num_senders :
_NvDsNmosNodeConfig
num_sink_pads :
_GstNvStreamMux
num_sink_sub_bins :
NvDsConfig
num_source_addresses :
_GstNvDsUdpSrc
num_source_sub_bins :
NvDsConfig
num_sources :
__AppCtx
Batch
NvDsSourceConfig
num_spot_views :
_Gstnvdewarper
num_streams :
_GstNvDsUdpSink
_GstNvDsUdpSrc
num_strings :
_GstNvDsOsd
_NvOSD_FrameTextParams
num_sub_comps :
_NvDsMetaCompLatency
num_surface_per_frame :
NvDsStreammuxConfig
num_surfaces_in_batch :
Batch
num_surfaces_per_frame :
_GstNvStreamDemux
_GstNvStreamMux
_NvDsFrameMeta
deepstream::FPSCounter
NvDsDewarperConfig
num_units :
GstNvDsPreProcessGroup
num_views :
nvspot_csv::_NvSpotCsvFields
numActivePayloads :
_GstNvMsgConv
numAllocated :
_NvDsTargetMiscDataBatch
_NvDsTargetMiscDataObject
_NvDsTargetMiscDataStream
_NvMOTObjToTrackList
_NvMOTTrackedObjBatch
_NvMOTTrackedObjList
numAttributes :
NvDsInferClassificationOutput
NvDsPostProcessClassificationOutput
numBuffers :
_NvMOTFrame
numClassesConfigured :
NvDsInferParseDetectionParams
NvDsPostProcessParseDetectionParams
numDetectedClasses :
numDims :
ds3d::Shape
NvDsInferDims
nvdsinferserver::InferDims
numel :
numElements :
NvDsInferDims
numFilled :
_NvDsReidTensorBatch
NvBufAudio
NvBufSurface
NvDsConvexHull
numFrames :
_NvMOTProcessParams
NvDsInferContextBatchOutput
NvDsPostProcessBatchOutput
numHostBuffers :
numInputFrames :
NvDsInferContextBatchInput
numInputTensors :
NvDsInferContextBatchPreprocessedInput
numLayerDevicePrecisions :
numObj :
numObjects :
DsExampleOutput
NvDsInferDetectionOutput
NvDsPostProcessDetectionOutput
numOffsets :
numOutputDeviceBuffers :
numOutputIOFormats :
numOutputLayers :
numPackets :
_GstNvDsUdpSrc
numPoints :
_NvDsObjConvexHull
numPointsAllocated :
_NvDsObjConvexHull
numROIpoints :
nvaisle_csv::_NvAisleCsvFields
numSink :
NvDsNmosAppConfig
numSrc :
NvDsNmosAppConfig
numTransforms :
_NvMOTConfig
_NvMOTQuery
TrackerConfig
nvanalytics :
AppCtx
nvbuf_mem_type :
deepstream::CameraInfo
nvbuf_memory_type :
NvDsDewarperConfig
NvDsDsExampleConfig
NvDsGieConfig
NvDsOSDConfig
NvDsSegVisualConfig
NvDsSinkRenderConfig
NvDsSourceConfig
NvDsStreammuxConfig
NvDsTiledDisplayConfig
nvdewarper :
NvDsDewarperBin
nvds_msgapi_connect :
_GstNvMsgBroker
nvds_msgapi_connect_ptr :
proto_adapter
nvds_msgapi_connection_signature_ptr :
proto_adapter
nvds_msgapi_disconnect :
_GstNvMsgBroker
nvds_msgapi_disconnect_ptr :
proto_adapter
nvds_msgapi_do_work :
_GstNvMsgBroker
nvds_msgapi_do_work_ptr :
proto_adapter
nvds_msgapi_get_protocol_name_ptr :
proto_adapter
nvds_msgapi_getversion_ptr :
proto_adapter
nvds_msgapi_send :
_GstNvMsgBroker
nvds_msgapi_send_async :
_GstNvMsgBroker
nvds_msgapi_send_async_ptr :
proto_adapter
nvds_msgapi_subscribe_ptr :
proto_adapter
nvdslogger :
AppCtx
nvdsosd_context :
_GstNvDsOsd
nvdsosd_mode :
_GstNvDsOsd
nvdspreprocess_groups :
_GstNvDsPreProcess
nvimagedec_init :
_GstNvImageDec
nvjpeg_encoder_state :
encode_params_t_
nvjpeg_handle :
decode_params_t_
encode_params_t_
nvjpeg_state :
decode_params_t_
encode_params_t_
nvjpeg_stream :
decode_params_t_
nvmmPtr :
NvBufSurfaceMappedAddr
nvmultiurisrcbin :
NvDsSrcParentBin
nvmultiurisrcbinCreator :
_GstDsNvMultiUriBin
AppCtx
nvosd :
AppCtx
NvDsOSDBin
nvosd_map :
_NvOSD_Ctx
nvsegvisual :
NvDsSegVisualBin
nvstreammux_eosmonitor_probe :
NvDsSrcParentBin
nvTracker_cb :
NvDsServerCallbacks
nvTracker_flag :
NvDsServerNvTrackerInfo
nvTracker_log :
nvtx_complete_buf_range :
GstDsExampleBatch
GstNvInferBatch
NvDsPreProcessBatch
nvtx_domain :
_GstDsExample
_GstNvDsPostProcess
_GstNvDsPreProcess
_GstNvInfer
nvvidconv :
_GstDsNvUriSrcBin
AppCtx
NvDsDewarperBin
NvDsOSDBin
NvDsPrimaryGieBin
NvDsSegVisualBin
NvDsSrcBin
nvvidconv2 :
AppCtx
nvvideoconvert_copy_hw :
Privacy Policy
Manage My Privacy
Do Not Sell or Share My Data
Terms of Service
Accessibility
Corporate Policies
Product Security
Contact
© 2025 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
NVIDIA Confidential | Subject to Change | For test and development only.
Tue Sep 9 2025 11:37:07 | PR-09318-R32
