Here is a list of all struct and union fields with links to the structures/unions they belong to:
- n -
- n_label_outputs
: NvDsGieConfig
- n_labels
: NvDsGieConfig
- n_pts
: PolyFillCommand
- name
: _FactoryMetadata
, deepstream::SignalHandler::Callback
, ds3d::config::ComponentConfig
, ds3d::gst::GstPtr< GstObjT, ObjFunc >
, mg_header
, mg_option
, NvDsFaceObject
, NvDsFaceObjectWithExt
, nvdsinferserver::InferBufferDescription
, nvdsinferserver::LayerDescription
, NvDsPlaceObject
- name_
: deepstream::Pipeline::StateTransitionMessage
- nArrows()
: deepstream::DisplayMetadata
- nb_subprotocols
: mg_websocket_subprotocols
- nCameraSources()
: deepstream::SourceConfig
- nChunks
: _GstNvDsUdpSink
- nCircles()
- ndim
: ds3d::v2xinfer::Tensor
- needCopyInputToHost()
: nvdsinferserver::InferBaseContext
- needInputCopy()
: nvdsinfer::InferPostprocessor
, nvdsinferserver::Postprocessor
- needKeepInputs()
: nvdsinferserver::BaseBackend
- needOutputCopyB4Processing()
- needPreprocess()
- needs_pool
: _GstNvImageDec
- netInputOrder
: _NvDsInferContextInitParams
- network_color_format
: NvDsPreProcessPropertySet
, NvDsPreProcessTensorParams
- network_height
: _GstNvInfer
- network_info
: _GstNvInfer
, NvDsInferTensorMeta
- network_input_order
- network_input_shape
- network_width
: _GstNvInfer
- networkInputFormat
- networkMode
, nvdsinfer::BuildParams
- NetworkPreprocessor()
: nvdsinferserver::NetworkPreprocessor
- networkScaleFactor
- networkSize
: CustomMeanSubandNormParams
- networkType
, _NvDsPostProcessContextInitParams
, nvdsinferserver::BasePostprocessor
- new_api
: NvDsSinkMsgConvBrokerConfig
- new_state_
- newAPI
: _GstNvMsgBroker
- newConnHandle
: _GstNvMsgBroker
- newLastError
: _GstNvMsgBroker
- next()
: deepstream::AbstractIterator< T >
- nextChunk
: _GstNvDsUdpSink
- nextReadyFrameNo
: RoiProcessedBuf
- nFrames()
: deepstream::BatchMetadata
- nLabels()
: deepstream::ClassifierMetadata
, deepstream::DisplayMetadata
- nLines()
- nmsIOUThreshold
: NvDsInferDetectionParams
, NvDsPostProcessDetectionParams
- no_pipeline_eos
: _GstNvStreamMux
, GstDsNvStreammuxConfig
, NvDsStreammuxConfig
- NONE
: deepstream::Tensor
- notify()
: ds3d::abiCallBackT< Args >
, ds3d::CBObjT< Args >
- notify_all()
: NvStreamMux
- notifyError()
: nvdsinferserver::IInferCustomProcessor
, nvdsinferserver::InferCudaContext
, nvdsinferserver::InferExtraProcessor
, nvdsinferserver::LstmController
, nvdsinferserver::StreamManager
- notifyLoadModelStatus()
: gstnvinfer::DsNvInferImpl
- nRects()
- nSources()
- ntp_calc_mode
: _GstNvStreamMux
- ntp_time_epoch_ns
: _NtpData
- ntp_timestamp
: _NvDsAudioFrameMeta
, _NvDsFrameMeta
- ntp_ts
: GstBufferWrapper
- ntpTimestamp()
: deepstream::FrameMetadata
, NvBufAudioParams
- num
: deepstream::VideoStreamInfo
- num_aisle_views
: _Gstnvdewarper
- num_arrows
: _GstNvDsOsd
, _NvOSD_FrameArrowParams
, NvDsDisplayMeta
- num_batch_buffers
: _Gstnvdewarper
, _GstNvDsAudioTemplate
, _GstNvDsVideoTemplate
, NvDsDewarperConfig
- num_bins
: NvDsSinkBin
, NvDsSrcParentBin
- num_blurs
: _GstNvDsOsd
- num_channels
- num_children
: NvDsSecondaryGieBinSubBin
, NvDsSecondaryPreProcessBinSubBin
- num_circles
: _GstNvDsOsd
, _NvOSD_FrameCircleParams
, NvDsDisplayMeta
- num_class_entries
: _GstNvDsOsd
- num_classes
: _NvDsLabelInfo
, _NvOSD_Ctx
, bevfusion::decoder::Decoder::DecoderParameter
- num_congestions
: NvDsEventMsgMeta
- num_conversations
: NvDsLLMObject
- num_coordinates
: NvDsInteractionObject
, NvDsTypeMetricsObject
- num_decode_surfaces
: NvDsSourceConfig
- num_embeddings
: NvDsLLMObject
- num_empty_elements
: _NvDsMetaPool
- num_extra_surfaces
: _GstDsNvUriSrcConfig
, NvDsSourceConfig
- num_filled_surfaces
: _NvDewarperSurfaceMeta
- num_fov
: NvDsEventMsgMeta
- num_fr_on
: NvDsSrcParentBin
- num_frames_in_batch
: _NvDsBatchMeta
- num_full_elements
: _NvDsMetaPool
- num_functions
: _NvDsNmosAssetConfig
- num_headers
: mg_request_info
, mg_response_info
- num_host_addresses
: _NvDsNmosNodeConfig
- num_instances
: NvDsAppPerfStruct
, NvDsAppPerfStructInt
- num_interactions
: NvDsEventMsgMeta
- num_joints
: NvDsJoints
- num_key_points
: NvDsPostProcessBodyPoseOutput
- num_labels
: _NvDsClassifierMeta
, NvDsDisplayMeta
- num_lines
: _GstNvDsOsd
, _NvOSD_FrameLineParams
, NvDsDisplayMeta
- num_local_interfaces
: _GstNvDsUdpSrc
- num_log_categories
- num_matches
: mg_match_context
- num_message_consumers
: NvDsConfig
- num_obj_meta
: _NvDsFrameMeta
- num_objectIds
: NvDsCongestionObject
, NvDsInteractionObject
- num_objects
: _NvDsBbox3dObjectList
- num_operate_on_class_ids
: NvDsGieConfig
- num_out_buffers
: NvDsDewarperConfig
, NvDsOSDConfig
- num_output_buffers
: _Gstnvdewarper
- num_output_layers
: NvDsInferTensorMeta
- num_planes
: NvBufSurfaceMapParams
, NvBufSurfacePlaneParams
- num_poses
: NvDsPersonPoseExt
- num_receivers
- num_rect
: _GstNvDsOsd
- num_rects
: _NvOSD_FrameRectParams
, NvDsDisplayMeta
- num_rtsp_reconnects
, NvDsSrcBin
- num_samples_per_frame
- num_secondary_gie_sub_bins
: NvDsConfig
- num_secondary_preprocess_sub_bins
: NvDsConfig
- num_segments
: _GstNvDsOsd
, _NvOSD_FrameSegmentMaskParams
- num_senders
- num_sink_pads
: _GstNvStreamMux
- num_sink_sub_bins
: NvDsConfig
- num_source_addresses
: _GstNvDsUdpSrc
- num_source_sub_bins
: NvDsConfig
- num_sources
: __AppCtx
, Batch
, NvDsSourceConfig
- num_spot_views
: _Gstnvdewarper
- num_streams
: _GstNvDsUdpSink
, _GstNvDsUdpSrc
- num_strings
: _GstNvDsOsd
, _NvOSD_FrameTextParams
- num_sub_comps
: _NvDsMetaCompLatency
- num_surface_per_frame
: NvDsStreammuxConfig
- num_surfaces_in_batch
: Batch
- num_surfaces_per_frame
: _GstNvStreamDemux
, _GstNvStreamMux
, _NvDsFrameMeta
, deepstream::FPSCounter
- num_units
: GstNvDsPreProcessGroup
- num_views
: nvspot_csv::_NvSpotCsvFields
- num_voxels()
: bevfusion::pointpillars::Voxelization
- num_voxels_device()
- numActivePayloads
: _GstNvMsgConv
- numAllocated
: _NvDsTargetMiscDataBatch
, _NvDsTargetMiscDataObject
, _NvDsTargetMiscDataStream
, _NvMOTObjToTrackList
, _NvMOTTrackedObjBatch
, _NvMOTTrackedObjList
- numAttributes
: NvDsInferClassificationOutput
, NvDsPostProcessClassificationOutput
- numBuffers
: _NvMOTFrame
- numClassesConfigured
: NvDsInferParseDetectionParams
, NvDsPostProcessParseDetectionParams
- numDetectedClasses
- numDims
: ds3d::Shape
, NvDsInferDims
, nvdsinferserver::InferDims
- numel
- numElements
: NvDsInferDims
- numFilled
: _NvDsReidTensorBatch
, _NvDsTargetMiscDataBatch
, NvBufAudio
, NvBufSurface
, NvDsConvexHull
- numFrames
: _NvMOTProcessParams
, NvDsInferContextBatchOutput
, NvDsPostProcessBatchOutput
- numHostBuffers
: NvDsInferContextBatchOutput
- numInputFrames
: NvDsInferContextBatchInput
- numInputTensors
: NvDsInferContextBatchPreprocessedInput
- numLayerDevicePrecisions
- numObj
: _NvDsTargetMiscDataObject
- numObjects
: DsExampleOutput
, NvDsInferDetectionOutput
, NvDsPostProcessDetectionOutput
- numOffsets
- numOutputDeviceBuffers
- numOutputIOFormats
- numOutputLayers
- numPackets
: _GstNvDsUdpSrc
- numPoints
: _NvDsObjConvexHull
- numPointsAllocated
- numROIpoints
: nvaisle_csv::_NvAisleCsvFields
- numSink
: NvDsNmosAppConfig
- numSrc
: NvDsNmosAppConfig
- numTransforms
: _NvMOTConfig
, _NvMOTQuery
, TrackerConfig
- NV12SourceCommand()
: NV12SourceCommand
- nvanalytics
: AppCtx
- nvBboxInfo()
: deepstream::ObjectMetadata
- nvbuf_mem_type
: deepstream::CameraInfo
- nvbuf_memory_type
: GstDsNvStreammuxConfig
, NvDsDsExampleConfig
, NvDsGieConfig
, NvDsOSDConfig
, NvDsSegVisualConfig
, NvDsSinkRenderConfig
, NvDsSourceConfig
, NvDsTiledDisplayConfig
- nvdewarper
: NvDsDewarperBin
- nvds_msgapi_connect
: _GstNvMsgBroker
- nvds_msgapi_connect_ptr
: proto_adapter
- nvds_msgapi_connection_signature_ptr
: proto_adapter
- nvds_msgapi_disconnect
: _GstNvMsgBroker
- nvds_msgapi_disconnect_ptr
: proto_adapter
- nvds_msgapi_do_work
: _GstNvMsgBroker
- nvds_msgapi_do_work_ptr
: proto_adapter
- nvds_msgapi_get_protocol_name_ptr
: proto_adapter
- nvds_msgapi_getversion_ptr
: proto_adapter
- nvds_msgapi_send
: _GstNvMsgBroker
- nvds_msgapi_send_async
: _GstNvMsgBroker
- nvds_msgapi_send_async_ptr
: proto_adapter
- nvds_msgapi_subscribe_ptr
: proto_adapter
- NvDsAnalyticCtx()
: NvDsAnalyticCtx
- NvDsBatchBufferWrapper()
: NvDsBatchBufferWrapper
- NvDsInferContextImpl()
: nvdsinfer::NvDsInferContextImpl
- NvDsKafkaAsyncSendCompl()
: NvDsKafkaAsyncSendCompl
- NvDsKafkaSyncSendCompl()
: NvDsKafkaSyncSendCompl
- NvDsKittiDump()
: deepstream::NvDsKittiDump
- nvdslogger
: AppCtx
- NvDsMemoryAllocator()
: NvDsMemoryAllocator
- NvDsModelEngineWatchOTFTrigger()
: deepstream::NvDsModelEngineWatchOTFTrigger
- nvdsosd_context
: _GstNvDsOsd
- nvdsosd_mode
: _GstNvDsOsd
- NvDsPostProcessObjectInfo()
: NvDsPostProcessObjectInfo
- nvdspreprocess_groups
: _GstNvDsPreProcess
- NvDsPreProcessAcquirerImpl()
: NvDsPreProcessAcquirerImpl
- NvDsPreProcessTensorImpl()
: NvDsPreProcessTensorImpl
- NvDsTilerEventHandler()
: deepstream::NvDsTilerEventHandler
- nvimagedec_init
: _GstNvImageDec
- nvjpeg_encoder_state
: encode_params_t_
- nvjpeg_handle
: decode_params_t_
, encode_params_t_
- nvjpeg_state
: decode_params_t_
, encode_params_t_
- nvjpeg_stream
: decode_params_t_
- nvmmPtr
: NvBufSurfaceMappedAddr
- nvmultiurisrcbin
: NvDsSrcParentBin
- nvmultiurisrcbinCreator
: _GstDsNvMultiUriBin
, AppCtx
- nvosd
: AppCtx
, NvDsOSDBin
- nvosd_map
: _NvOSD_Ctx
- nvsegvisual
: NvDsSegVisualBin
- NvStreamMux()
: NvStreamMux
- nvstreammux_eosmonitor_probe
: NvDsSrcParentBin
- NvTimeSync()
: NvTimeSync
- nvTracker_cb
: NvDsServerCallbacks
- nvTracker_flag
: NvDsServerNvTrackerInfo
- nvTracker_log
- NvTrackerProc()
: NvTrackerProc
- nvtx_complete_buf_range
: GstDsExampleBatch
, GstNvInferBatch
, NvDsPreProcessBatch
- nvtx_domain
: _GstDsExample
, _GstNvDsPostProcess
, _GstNvDsPreProcess
, _GstNvInfer
- nvtxDomain()
: gstnvinferserver::GstNvInferServerImpl
- nvvidconv
: _GstDsNvUriSrcBin
, AppCtx
, NvDsDewarperBin
, NvDsOSDBin
, NvDsPrimaryGieBin
, NvDsSegVisualBin
, NvDsSrcBin
- nvvidconv2
: AppCtx
- nvvideoconvert_copy_hw
