Here is a list of all struct and union fields with links to the structures/unions they belong to:
- c -
- c
: NvDsInferDimsCHW
- c0
: cuOSDContextCommand
- c1
- c2
- c2d_ctx
: _AppCtx
- c3
- c_instance
: NvDsKafkaClientHandle
- cached_info
: _GstNvInferObjectHistory
, _NvDsPostProcessObjectHistory
, gstnvinferserver::GstNvInferServerObjectHistory
- cacheSize
: NvDsSRInitParams
- cafile
: NvDsMqttClientHandle
- cairo_context
: _NvOSDFdMap
- calcEncodeTime
: _NvDsObjEncUsrArgs
- calculate_delay()
: BatchPolicy
- calculate_wait()
: BatchPolicy
- callback
: NvDsAppPerfStructInt
, NvDsSRInitParams
- callbacks
: mg_init_data
- camera_csi_sensor_id
: deepstream::CameraInfo
, NvDsSourceConfig
- camera_fps_d
- camera_fps_n
- camera_height
- camera_id
: _NvDsBbox3dObjectList
, NvDsSourceConfig
- camera_info_
: deepstream::SourceConfig
- camera_type
- camera_v4l2_dev_node
, NvDsSourceConfig
- camera_video_format
- camera_width
- CameraCanApp()
: CameraCanApp
- cameraId
: nvaisle_csv::_NvAisleCsvFields
, nvspot_csv::_NvSpotCsvFields
- cameraIDString
- cameraIdString
: nvspot_csv::_NvSpotCsvFields
- cameraInfo
: NvDsCanContextConfig
- cancellable
: _GstNvDsUdpSrc
- cancellableFd
: _GstNvDsUdpSrc
- canSupportBatchDims()
: nvdsinfer::BackendContext
, nvdsinfer::TrtBackendContext
- canSupportGpu()
: gstnvinferserver::GstNvInferServerImpl
- cap
: NvDsFaceObject
, NvDsFaceObjectWithExt
, NvDsPersonObject
, NvDsPersonObjectExt
- cap_filter
: _GstDsNvUriSrcBin
, NvDsDewarperBin
, NvDsDsExampleBin
, NvDsOSDBin
, NvDsSegVisualBin
, NvDsSinkBinSubBin
, NvDsSrcBin
- cap_filter1
: _GstDsNvUriSrcBin
, NvDsSrcBin
- capath
- caps
: _GstNvDsUdpSrc
, _GstNvVideoTestSrc
- car_class_id
: _AppCtx
- case_sensitive
: mg_match_context
- cast()
: ds3d::GuardDataT< Tp >
- category
: bevfusion::decoder::ThreeDBox
- CBObjT()
: ds3d::CBObjT< Args >
- cbType
- centerX
: ds3d::IntrinsicsParam
, ds3d::Lidar3DBbox
, ds3d::Object2DBbox
- centerY
, ds3d::Lidar3DBbox
- centerZ
: ds3d::Lidar3DBbox
- certfile
- cfg_file
: gstnvinfer::ModelStatus
- channelAlign
: BatchSurfaceInfo
- channels
: _GstNvDsAudioAllocatorParams
, deepstream::AudioStreamInfo
, NvBufAudioParams
, NvDsInferNetworkInfo
, NvDsPreProcessNetworkSize
, NvDsSRRecordingInfo
- check()
: ds3d::impl::filter::Config
- check_and_update_defaults()
: BatchPolicy
- check_past_min()
: BatchPolicy
- check_queue_empty()
: SinkPad
- check_repeats_per_batch()
: BatchPolicy
- check_source()
: Batch
- checkInferOutputs()
: nvdsinferserver::InferExtraProcessor
- checkInputDims()
: nvdsinferserver::BaseBackend
- chromaLocHoriz
: NvBufSurfaceChromaSubsamplingParams
- chromaLocVert
- chromaSubsampling
: NvBufSurfaceAllocateParams
, NvBufSurfaceMapParams
, NvBufSurfaceParamsEx
- chunk_id
: deepstream::_NvDsSourceMeta
- chunk_ids_
: deepstream::Buffer
- chunkDuration
: _NvMOTMFTrackedObjMeta
- chunkId()
- chunkNum
: StreamParams
- chunks
: _GstNvDsUdpSink
- chunkSize
: StreamParams
- chunksPerFrame
: StreamParams
- chunksPerMemblock
: StreamParams
- cid
: ds3d::Lidar3DBbox
- cinfo
: consumer_instance_t
- cintr
: _AppCtx
- circle_color
: _NvOSD_CircleParams
- circle_params
: _GstNvDsOsd
, NvDsDisplayMeta
- circle_params_list
: _NvOSD_FrameCircleParams
- circle_width
- CircleCommand()
: CircleCommand
- class_id
: _NvDsAudioFrameMeta
, _NvDsObjectMeta
, ImageMetaProducer::IPData
, ObjInf
- class_label
- class_map
: NvDsInferSegmentationMeta
, NvDsInferSegmentationOutput
, NvDsPostProcessSegmentationOutput
- class_name
: ImageMetaProducer::IPData
- class_probabilities_map
- class_probability_map
: NvDsInferSegmentationOutput
- classes
- classId
: _NvDsTargetMiscDataObject
, _NvMOTObjToTrack
, _NvMOTTrackedObj
, deepstream::ObjectMetadata
, NvDsInferInstanceMaskInfo
, NvDsInferObjectDetectionInfo
, NvDsPostProcessInstanceMaskInfo
, NvDsPostProcessObjectDetectionInfo
- classificationOutput
: NvDsInferFrameOutput
- ClassificationOutput()
: nvdsinferserver::ClassificationOutput
: NvDsPostProcessFrameOutput
- classifier
: NvDsAudioClassifierBin
- classifier_async_mode
: _GstNvInfer
- classifier_meta_list
, _NvDsObjectMeta
, NvDsRoiMeta
- classifier_meta_pool
: _NvDsBatchMeta
- classifier_type
: _GstNvInfer
, _NvDsClassifierMeta
, _NvDsPostProcessContextInitParams
- ClassifierMetadata()
: deepstream::ClassifierMetadata
- classifierThreshold
: _NvDsInferContextInitParams
- classifierType()
, gstnvinferserver::GstNvInferServerProperties
- ClassifyModelPostProcessor()
: ClassifyModelPostProcessor
- ClassifyPostprocessor()
: nvdsinfer::ClassifyPostprocessor
, nvdsinferserver::ClassifyPostprocessor
- classIndex
: NvDsInferObject
- classParams()
: nvdsinferserver::TrtServerRequest
- clear()
: ds3d::GuardDataMap
, ds3d::SafeQueue< T, Container >
, INFER_EXPORT_API::GuardQueue< Container >
, INFER_EXPORT_API::MapBufferPool< Key, UniqBuffer >
, nvdsinfer::GuardQueue< Container >
- clear_frames()
: SinkPad
- clear_i()
: ds3d::abiDataMap
- clearAll()
: BufferManager
- client
: TestOps
- client_cert
: mg_client_options
, mg_request_info
- client_id
- client_test1
: UcxTest
- client_test2
: UcxTest
- client_test3
: UcxTest
- clip_object_outside_roi
: _GstNvInfer
- clipBBox()
: NvTrackerProc
- clk_params
: _NvOSD_Ctx
- cLocation
: nvwarpYUVRGBParams_t
- clock_color
: _GstNvDsOsd
, NvDsOSDConfig
- clock_font_size
: _GstNvDsOsd
- clock_rate
: _GstNvDsUdpSrc
- clock_text_params
: _GstNvDsOsd
- clock_text_size
: NvDsOSDConfig
- clock_x_offset
: NvDsOSDConfig
- clock_y_offset
: NvDsOSDConfig
- clone()
: deepstream::Tensor
, deepstream::VideoBuffer
, ds3d::v2xinfer::Tensor
, nvinfer1::plugin::BEVPoolPlugin
, nvinfer1::plugin::PillarsScatterPlugin
- close()
: ds3d::profiling::FileReader
, ds3d::profiling::FileWriter
- close_socket
: _GstNvDsUdpSink
- CloseCB
: ds3d::abiWindow
- Cloud2DeviceReceiver()
: deepstream::Cloud2DeviceReceiver
- cls_scores
: _NvDsBbox3dObject
- clusterMode
- code()
: ds3d::Exception
, mg_error_data
, NvDsServerErrorInfo
- code_sub
: mg_error_data
- codec
: deepstream::StreamInfo
, NvDsSinkEncoderConfig
- codec_type
: NvDsYamlCodecStatus
- codecparse
: NvDsSinkBinSubBin
- cOffset
- collectReady()
: BufferManager
- color
: _NvOSD_Color_info
, NvDsVehicleObject
, NvDsVehicleObjectExt
- color_bg
: _NvBufSurfTransformCompositeBlendParams
- color_format
: GstNvDsPreProcessVideoBufferAllocatorInfo
- color_id
: _NvOSD_RectParams
- color_info
: _GstNvDsOsd
- color_params
: NvDsPostProcessDetectionParams
- color_range
: NvDsSinkRenderConfig
- colorFormat
: NvBufSurfaceCreateParams
, TrackerConfig
- colorFormats
: _NvMOTQuery
- cols
: NvDsOpticalFlowMeta
- columns
: NvDsTiledDisplayConfig
- common_elements
: NvDsPipeline
- CommonFactory()
: deepstream::CommonFactory
- comp_in_timestamp
: NvDsFrameLatencyInfo
- compConfig
, ds3d::impl::lidarsource::Config
- compId
: _GstNvMsgBroker
, _GstNvMsgConv
- COMPLEX
- component_name
: _NvDsMetaCompLatency
- componentId
: NvDsEventMsgMeta
, NvDsPayload
- composite_blend_filter
, _NvBufSurfTransformCompositeBlendParamsEx
- composite_blend_flag
- composite_filter
: _NvBufSurfTransformCompositeParams
- composite_flag
- compute_grid_size()
: bevfusion::pointpillars::VoxelizationParameter
- compute_hw
: _GstNvDsPostProcess
, _GstNvDsVideoTemplate
, GstDsNvStreammuxConfig
, NvDsStreammuxConfig
, NvDsTiledDisplayConfig
, NvDsTrackerConfig
, TrackerConfig
- compute_mode
: _NvBufSurfTransformConfigParams
- compute_y_offset()
: TextBackend
- computeConfig
: _NvMOTConfig
, _NvMOTQuery
- computeStatus
: _NvMOTConfigResponse
, _NvMOTMFConfigResponse
- computeTarget
: TrackerConfig
- confidence
, _NvDsObjectMeta
, _NvDsTargetMiscDataFrame
, _NvMOTObjToTrack
, _NvMOTTrackedObj
, NvDsEventMsgMeta
, NvDsInferObject
, NvDsJoint
- config
: _AppCtx
, _GstDsNvMultiUriBin
, _GstDsNvUriSrcBin
, AppCtx
, AppProfiler
, CameraCanApp
, Component
, consumer_instance_t
, ds3d::gst::DataProcessInfo< GuardProcess >
, gstnvinferserver::GstNvInferServerImpl
, nvdsinferserver::InferBaseContext
, NvDsNmosAppCtx
, NvDsSrcBin
- config_file
: _Gstnvdewarper
, NvDsDewarperConfig
- config_file_available
: _GstNvStreamMux
- config_file_parse_successful
: _GstNvDsAnalytics
, _GstNvDsPreProcess
, _GstNvInfer
, _GstNvStreamMux
- config_file_path
: _GstNvDsAnalytics
, _GstNvInfer
, _GstNvStreamMux
, CustomInitParams
, deepstream::Cloud2DeviceReceiver::Config
, NvDsDsAnalyticsConfig
, NvDsGieConfig
, NvDsMsgConsumerConfig
, NvDsPreProcessConfig
, NvDsServerAnalyticsInfo
, NvDsSinkMsgConvBrokerConfig
- config_height
: StreamInfo
- config_params
- config_path
: NvDsServerNvTrackerInfo
- config_width
: StreamInfo
- configBody
: ds3d::config::ComponentConfig
- configBuilder()
: nvdsinfer::BuildParams
- configContent
: ds3d::DataProcessUserData
- configFile
: _GstNvMsgBroker
, _GstNvMsgConv
, NvDsC2DContext
- configPath
, ds3d::impl::filter::Config
- configStr
: NvTrackerProc::UpdateDynamicConfigInfo
- configuration_height
: _GstNvDsAnalytics
- configuration_options
: mg_init_data
- configuration_width
: _GstNvDsAnalytics
- configurePlugin()
: nvinfer1::plugin::BEVPoolPlugin
- congestions
: NvDsEventMsgMeta
- conn_data
: mg_request_info
- conn_id
- conn_str
: deepstream::Cloud2DeviceReceiver::Config
- connect()
- connect_cb
- connect_cb_set
: NvMsgBrokerHandle
- connection_close
: mg_callbacks
- connection_closed
: mg_callbacks
- connection_str
- connectSignal()
: deepstream::Element
- connHandle
: _GstNvMsgBroker
, NvDsC2DContext
- connStr
: _GstNvMsgBroker
, NvDsC2DContext
- consume()
: deepstream::DataReceiver
, deepstream::DataReceiver::IDataConsumer
, deepstream::EnsembleRender
, deepstream::ObjectCounter
- consumer
- consumer_grp_id
- consumer_tid
: consumer_thread_info
- container
: NvDsSinkEncoderConfig
- containerType
: NvDsSRInitParams
- containsAudio
: NvDsSRRecordingInfo
- containsVideo
- content_length
: mg_request_info
, mg_response_info
- context
- context_
- contextHandle
: _NvMOTMFQuery
, _NvMOTQuery
, NvTrackerProc::DispatchInfo
- ContextReplacementPtr
: gstnvinfer::DsNvInferImpl
- control
: _NvDewarperParams
, nvwarpParams_t
- controlMode
: nvdsinferserver::triton::RepoSettings
- conv_buf
: _GstNvDsOsd
, _NvOSD_Ctx
, GstNvInferBatch
- conv_cb
: NvDsServerCallbacks
- conv_comp_id
: NvDsSinkMsgConvBrokerConfig
- conv_dummy_payload
- conv_flag
: NvDsServerConvInfo
- conv_frame_interval
- conv_log
- conv_msg2p_lib
- conv_msg2p_new_api
- conv_payload_type
- conv_queue
: NvDsDewarperBin
, NvDsOSDBin
, NvDsSegVisualBin
- ConvBufManager()
: ConvBufManager
- conversations
: NvDsLLMObject
- convert_stream
: _GstNvDsPreProcess
- convertBatchAsync()
: ConvBufManager
- converted_buf
: NvDsPreProcessBatch
- converted_buffer
: NvDsRoiMeta
- converted_frame_ptr
: GstNvInferFrame
, NvDsPreProcessUnit
- convertStream
: _GstNvInfer
- convexHull
: _NvMOTTrackedObj
, NvDs3DTracking
- coordinate
: NvDsEventMsgMeta
, NvDsPlaceObject
, NvDsSensorObject
- coordinates
: NvDsInteractionObject
, NvDsTypeMetricsObject
- copy()
: BatchBufferWrapper
, deepstream::UserMetadataTemplate< C, N >
, ds3d::gst::GstPtr< GstObjT, ObjFunc >
, ds3d::GuardDataMap
- copy_batch()
: NvStreamMux
- copy_buf()
: GstAudioBatchBufferWrapper
, GstBatchBufferWrapper
, NvDsBatchBufferWrapper
- copy_device_to_host()
: Memory< T >
- copy_from_device()
: ds3d::v2xinfer::Tensor
- copy_from_host()
- copy_func
: _NvDsBaseMeta
, _NvDsMetaPool
- copy_host_to_device()
: Memory< T >
- copy_i()
: ds3d::abiDataMap
- copy_meta()
- copyBuffersToHostMemory()
: nvdsinfer::InferPostprocessor
- copyfunc
: _NvDsMeta
- copyInputToHostBuffers
- cost
- cost_size
- count
, NvDsEventMsgMeta
- count_mutex
: deepstream::FPSCounter
- CountMarker()
: deepstream::CountMarker
- CppFunc
: ds3d::abiCallBackT< Args >
- CPU
- CpuMem()
: nvdsinferserver::CpuMem
- CpuMemBuf()
: ds3d::CpuMemBuf
- create()
, ds3d::v2xinfer::TensorData
, NvDsAnalyticCtx
, NvDsSecondaryGieBinSubBin
, NvDsSecondaryPreProcessBinSubBin
- create_()
- create_x_window()
: deepstream::NvDsTilerEventHandler
- CreateBuf()
: ds3d::CpuMemBuf
, ds3d::GpuCudaMemBuf
- CreateBufferPool()
: DSCustomLibraryBase
- CreateCtx()
: ds3d::CustomLibFactory
- CreateCustomAlgoCtx()
: DSCustomLibrary_Factory
, DSPostProcessLibrary_Factory
, nvdsspeech::DSCustomLibrary_Factory
, nvdstts::DSCustomLibrary_Factory
- createDecoder()
: bevfusion::decoder::Decoder
- createNNBackend()
: nvdsinferserver::InferGrpcContext
, nvdsinferserver::InferSimpleContext
- createNvBufSurface
: nvdsinferserver::SurfaceBuffer
- createObject()
, deepstream::CustomFactory
- createPlugin()
: nvinfer1::plugin::BEVPoolPluginCreator
, nvinfer1::plugin::PillarsScatterPluginCreator
- createPostprocessor()
: nvdsinferserver::InferCudaContext
- createPreprocessor()
- createRequest()
: nvdsinferserver::InferGrpcClient
, nvdsinferserver::TrtISServer
- createResponsePool()
: nvdsinferserver::TrtISBackend
- crop_objects_to_roi_boundary
: _GstNvInfer
- CROPPED_TO_OBJECT
: ImageMetaConsumer
- CropSurfaceConverter()
: nvdsinferserver::CropSurfaceConverter
- CSV
: ImageMetaConsumer
- ctx
- ctx_create
: _GstNvMsgConv
- ctx_destroy
: _GstNvMsgConv
- ctx_lock
: _GstNvStreamDemux
, _GstNvStreamMux
- cu_nbstream
- cuda_block_size
: _GstNvVideoTestSrc
- cuda_fill_image
- cuda_mem_type
: _Gstnvdewarper
, BufferPoolConfig
- cuda_memory_type
: _GstDsNvUriSrcConfig
, NvDsSourceConfig
- cuda_num_blocks
- cuda_resources
: GstNvDsPreProcessMemory
, GstNvInferMemory
- cuda_stream
: _GstDsExample
, _GstNvDsUdpSink
, _NvBufSurfTransformConfigParams
- cuda_surf
- CudaBuffer()
: CudaBuffer
- cudaBuffer
: NvBufSurfaceParams
- CudaBuffer()
: nvdsinfer::CudaBuffer
- CudaDeviceBuffer()
: CudaDeviceBuffer
, nvdsinfer::CudaDeviceBuffer
- CudaDeviceMem()
: nvdsinferserver::CudaDeviceMem
- cudaDevMemMap
- CudaEvent()
: nvdsinfer::CudaEvent
, nvdsinferserver::CudaEvent
- CudaHostBuffer()
: nvdsinfer::CudaHostBuffer
- CudaHostMem()
: nvdsinferserver::CudaHostMem
- cudaPtr
: NvBufSurfaceMappedAddr
- CudaStream()
: CudaStream
, ds3d::CudaStream
, nvdsinfer::CudaStream
, nvdsinferserver::CudaStream
- CudaTensorBuf()
: nvdsinferserver::CudaTensorBuf
- cuEvent()
: nvdsinferserver::BaseBatchArray
, nvdsinferserver::BaseBatchBuffer
- cuosd_context
: _NvOSD_Ctx
- cur_frame_pts
: _GstNvStreamMux
- current_batch_num
: _GstDsExample
, _GstNvInfer
, _GstNvInferServer
- current_frame
- custom_cb_endpt
- custom_initparams
- custom_lib_ctx
- custom_lib_handle
- custom_lib_name
: _GstNvDsA2Vtemplate
, _GstNvDsAudioTemplate
- custom_lib_path
, NvDsPreProcessPropertySet
- custom_metadata_ptr
: _GstAudioTemplateMeta
- custom_metadata_size
- custom_metadata_type
- custom_prop_string
- custom_tensor_function
- custom_tensor_function_name
- custom_transform
: GstNvDsPreProcessGroup
- custom_transform_function_name
- custom_ts_to_rfc
: NvDsConfig
- customBBoxInstanceMaskParseFuncName
- customBBoxParseFuncName
- customClassifierParseFuncName
- customConfigFilePath
: _NvMOTConfig
, _NvMOTMFConfig
- customConfigFilePathSize
: _NvMOTConfig
, _NvMOTMFConfig
- customConfigStatus
- customCreateFunction
- customEngineCreateFuncName
- CustomFactory()
: deepstream::CustomFactory
- customlib
- customLib()
: nvdsinferserver::InferBaseContext
- CustomLibFactory()
- customLibPath
, ds3d::config::ComponentConfig
- CustomModelParser()
: nvdsinfer::CustomModelParser
- customNetworkConfigFilePath
- CustomObject()
: deepstream::CustomObject
- customProcessor
: ds3d::gst::DataProcessInfo< GuardProcess >
- customSegmentationParseFuncName
- cv
: NvMsgBrokerThread_t
, SinkPad
- cv_
- cv_data_
: deepstream::DataFeeder
- cv_input_full
: SinkPad
- cvmat
: _GstNvDsVideoTemplate
- cx
: CircleCommand
- cx0
- cx1
, RectangleCommand
- cx2
, RectangleCommand
- cx3
- cy
: CircleCommand
- cy0
- cy1
, RectangleCommand
- cy2
, RectangleCommand
- cy3
